Old 20-05-2011, 12:48 PM   #1 (permalink)
SixAxis TechNolOgy
Patriot's Avatar
Angry Too many SVCHOST.EXE running in process list...
atleast 10 in my case,
And they're consuming quiet a lot of memory and thus slowing down PC performance, what are these files and why r they taking up so much memory..?
Plz help...
Patriot is offline   Reply With Quote
Old 20-05-2011, 01:03 PM   #2 (permalink)
Simply a DIGITian
krishnandu.sarkar's Avatar
Default Re: Too many SVCHOST.EXE running in process list...
Well, it's normal. This is same in my case.
BTW svchost can be virus too, run a scan in the meantime.
You can check about suspicious process here : ProcessLibrary.com - The Online Resource For Process Information!
  • Read The Forum RULES First.
  • Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
  • Before Starting A New Thread Read The STICKY THREADS First
  • Before Participating In Bazaar Section Read The BAZAAR RULES
krishnandu.sarkar is offline   Reply With Quote
Old 20-05-2011, 03:41 PM   #3 (permalink)
Dust in the Wind
Skud's Avatar
It's normal. BTW, svchost.exe is not a virus, various viruses create similar looking files, like SVCCHOST.exe, scvhost.exe etc.
Gaming Rig:
i7 2600K || CM N620 || ASUS P8Z68 Deluxe || 2x4GB GSkill RipjawsX 1600MHz || OCZ Vertex 3 120GB || Razer Cyclosa Bundle || Sapphire 6950 1GB || BenQ G2420HD || Corsair HX750 || Lancool K62 || Altec Lansing VS2421 || ASUS Vulcan ANC || NZXT Sentry Mesh
HTPC Rig:
C2D E7400 || Gigabyte EP45-DS3R || 2x2GB DDR2 800 || 9TB || MS Wireless Desktop 2000 || Gigabyte 5770 || Samsung 32" || Seasonic SII 520W || Silverstone LC10
Samsung Galaxy R I9103
Will be off/irregular for a month...
Skud is offline   Reply With Quote
Old 20-05-2011, 03:51 PM   #4 (permalink)
It is a windows file and not a virus. But it can be virus infected. Update your antivirus (I am sure you will be using it). And do full system scan (at least your Windows Installation Drive) in safe mode.
abhijangda is offline   Reply With Quote
Old 20-05-2011, 04:43 PM   #5 (permalink)
Super Moderator
asingh's Avatar
Just run a deep level virus scan. Post that, how ever many you have = Normal.
asingh is offline   Reply With Quote
Old 20-05-2011, 07:22 PM   #6 (permalink)
Living to Play
gameranand's Avatar
Well it normal just see that none of them is ran by the username of the computer. If that is the case then you are infected with some nasty virus.
In war, Victory. In peace, Vigilance. In death, Sacrifice.
Using TDF through mobile. Digit optimized this forum for mobiles. Works nicely YAY :D:D
gameranand is offline   Reply With Quote
Old 21-05-2011, 10:39 AM   #7 (permalink)
do a scan using this online antivirus just to be sure and for safety
http://housecall.trendmicro.com
