You can try removing the single quote from Text to Column feature of excel.
Note: Following guide is for Excel 2007:
- First make sure, the column is in text format.
- Select the column. Right Click on selected column -> Format Cells. In number tab, select Text from the list. And click Ok.
- Now, click Data tab on Ribbon -> Select Text to Column
- Select Fixed Width radio button. Click Next.
- Click select and make the line, on the scale, such that, single quote is selected.
- Now Click next.
- Then click finish. Make sure, the adjacent column was blank, or this process can overwrite the column.
Now you can delete the column of single quote, and proceed to sort.
Hope that works.
Marty: Hey, Doc, we better back up. We don't have enough road to get up to 88.
Doc Brown: Roads? Where we're going, we don't need, "roads!" :)
──── On the Internet you can be Anything you want. It's Strange that, so many people choose to be Stupid! ────
