Old 05-05-2011, 03:20 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Question crc errors
I have a series of rar files (.r00, .r01, etc. - I do know how to work with
such files). When I try to extract the one big file that's stored in these
file, I get "CRC error in .rxx, file is corrupt"..is there a way to fix
these CRC errors?
roy.banit is offline   Reply With Quote
Old 05-05-2011, 03:45 PM   #2 (permalink)
Living to Play
gameranand's Avatar
Default Re: crc errors
First of all you have to use Winrar for that because 7zip many times gives problem. And then you have to extract from *.r00 file and if the error occurs then file is corrupted and you can't do anything about it.
In war, Victory. In peace, Vigilance. In death, Sacrifice.
Using TDF through mobile. Digit optimized this forum for mobiles. Works nicely YAY :D:D
gameranand is offline   Reply With Quote
Old 05-05-2011, 03:45 PM   #3 (permalink)
Simply a DIGITian
krishnandu.sarkar's Avatar
No, they itself got corrupt while compressing.
BTW if I guess correct it's a game which you downloaded from net, pirated of course.
And if it's that, then they itself is corrupt, nothing wrong at your end.
  • Read The Forum RULES First.
  • Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
  • Before Starting A New Thread Read The STICKY THREADS First
  • Before Participating In Bazaar Section Read The BAZAAR RULES
krishnandu.sarkar is offline   Reply With Quote
Old 05-05-2011, 03:47 PM   #4 (permalink)
Super Moderator
asingh's Avatar
Get the archive again from the source. It is corrupt.
asingh is offline   Reply With Quote
Old 05-05-2011, 03:53 PM   #5 (permalink)
are they on a CD? If they are, I think CD is damaged
Old 05-05-2011, 04:24 PM   #6 (permalink)
Fullbring
Zangetsu's Avatar
@gameranand: How do u know OP is using 7Zip???
these CRC errors?
CRC: cyclic redundancy check.happens due to Bad Scetor in HardDrive or when file checksum is damaged....
use HJsplit to do a hashcheck of files if they r proper or not.
Not necessary... can start from any file
Old 05-05-2011, 04:25 PM   #7 (permalink)
i have downloaded these multiple rar files and i tried with winzip ,7zip,winrar,universal extractor, but none worked . I dont think files would be corrupt because i read the comments well.
Old 05-05-2011, 04:34 PM   #8 (permalink)
Fullbring
Zangetsu's Avatar
oww..downloaded from torrent....cant help u on that...sorry
Old 05-05-2011, 04:54 PM   #9 (permalink)
not torrent actualyy....but mediafire links
Old 05-05-2011, 06:20 PM   #10 (permalink)
^^ same. re-download & try.
Old 05-05-2011, 06:39 PM   #11 (permalink)
Super Moderator
asingh's Avatar
You can get the CRC if:
1. HDD is bad.
2. Optical media is bad (DVD/CD).
3. The DL'ed archive was not downloaded correctly.
In this case it seems like (3). Try it again.
Old 05-05-2011, 06:59 PM   #12 (permalink)
abhidev's Avatar
Try this...
Open the archive in winrar....got to 'Tools'...and select 'Repair archive'......it might get repaired
Core 2 duo E4500 2.2gHz , ASUS P5GCMX , 3GB Transcend , Corsair VX 550w, MSI R5770 HAWK Edition 1GB, CM HAF-922, LG W2243T 21.5" LCD, I-Ball Baton
abhidev is offline   Reply With Quote
Old 05-05-2011, 08:21 PM   #13 (permalink)
Living to Play
gameranand's Avatar
I didn't. But whenever I try to extract those files using 7zip the error occurs so I gave him advice to not to use 7zip as it would give error even with completely fine files.
Originally Posted by abhidev
Try this...
It hardly does anything at all. Most files don't get repaired at all.
Just a precaution.
Old 06-05-2011, 12:00 PM   #14 (permalink)
abhidev's Avatar
Thats not the case....OP said he has downloaded it form mediafire...and when you upload large amount of files on a file server they tend to get corrupt....so if the archive has any recoverable records then repairing it will fix the problem
Old 06-05-2011, 12:03 PM   #15 (permalink)
Fullbring
Zangetsu's Avatar
archive repair is only possible when u create archive with recovery feature ON...this will increase the size of file after archiving & generally no uploader uses that feature to keep the size as low as possible
Old 06-05-2011, 03:03 PM   #16 (permalink)
abhidev's Avatar
As far as i know...those who upload it on mediafire generally do it with recoverable records....also the size isn't increased considerably...depends on how much % of the archive has gone corrupt...
Old 06-05-2011, 04:08 PM   #17 (permalink)
Living to Play
gameranand's Avatar
As far as my experience says they don't. Actually most don't even notice this feature at all and just compress and upload.
Old 06-05-2011, 04:10 PM   #18 (permalink)
Fullbring
Zangetsu's Avatar
ya u r right buddy
Old 06-05-2011, 05:30 PM   #19 (permalink)
Electronic.
Neuron's Avatar
If you have a pendrive or memory card of suitable size it can solve the problem.Directly download the source files into the pendrive and extract them into the pendrive itself.It will work.
I don't always make sense,but when I do,I don't.
Neuron is offline   Reply With Quote
Old 06-05-2011, 07:55 PM   #20 (permalink)
Living to Play
gameranand's Avatar
If the file itself is corrupted then how the hell would it work. I mean if the source itself is corrupted then how would it work at all.
Old 06-05-2011, 08:14 PM   #21 (permalink)
Electronic.
Neuron's Avatar
OP said that he found positive comments.So the source files are probably not corrupted.And of course that won't work in case they are.
Old 09-05-2011, 10:42 AM   #22 (permalink)
abhidev's Avatar
But how will a pen drive help??
Old 09-05-2011, 11:35 AM   #23 (permalink)
Electronic.
Neuron's Avatar
Pendrive will help since probably it's a case of hard drive failure.
LinkBack to this Thread: http://www.thinkdigit.com/forum/software-q/140279-crc-errors.html
Site Digit Forum | www.thinkdigit.com | BoardReader This thread Refback 06-05-2011 04:42 AM
