Old 05-05-2011, 02:11 PM   #1 (permalink)
A PC GAMER
Gaurav265's Avatar
Unhappy need help about softwares important !
hi,friends i need name of some softwares and your ideas how to do.problem is, i want to write notes on physics class 12th cbse.this is competion in My friends that whose note is beter.IN My pc i think write it in ms word but there is problem about figures ,how to make figures of resistors,capacitors and others electrical applience roughly.it can be done in paint but how make all in one place.i has seen the figures my friends draw but they dont tell me how they do that.
so,some best softwares and ideas are needed. pls coment some ideas all of you so i can do best in my project.i have rough note in my copy only need to write in pc and print.
i am very happy to know your ideas.i can download any soft. you mention only say the name.
your friend
Gaurav
Gaurav265 is offline   Reply With Quote
Old 05-05-2011, 02:50 PM   #2 (permalink)
Simply a DIGITian
krishnandu.sarkar's Avatar
Default Re: need help about softwares important !
You can perform the rough drawing in Word too, using Drawing tools.
BTW don't mind, at your competition at this age
  • Read The Forum RULES First.
  • Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
  • Before Starting A New Thread Read The STICKY THREADS First
  • Before Participating In Bazaar Section Read The BAZAAR RULES
krishnandu.sarkar is offline   Reply With Quote
Old 05-05-2011, 03:51 PM   #3 (permalink)
Living to Play
gameranand's Avatar
If you use office 2010 then there is a option to insert symbols in top right corner under Insert Ribbon. Can't say about other versions there should be a way but I don't remember. Also you can draw symbols in word itself or save the image in Paint and insert that. All options are open.
In war, Victory. In peace, Vigilance. In death, Sacrifice.
Using TDF through mobile. Digit optimized this forum for mobiles. Works nicely YAY :D:D
gameranand is offline   Reply With Quote
Old 05-05-2011, 04:01 PM   #4 (permalink)
cute.bandar's Avatar
onenote is meant for note-taking. Not sure about inserting figures though
Computer parts search Engine(for india) : http://goo.gl/Sg8Yv
cute.bandar is offline   Reply With Quote
Old 05-05-2011, 04:19 PM   #5 (permalink)
Fullbring
Zangetsu's Avatar
@Gaurav265: u want to draw diagrams of resisters & capacitors & other electrical appliances.
u can use coral draw or smart draw
also AutoCAD is also good.
I guess ur frnds r googling for the required images & pasting it in their doc notes
Old 06-05-2011, 02:02 AM   #6 (permalink)
XLr8
arpanmukherjee1's Avatar
err.... i dont think the above mentioned s/w are necessary.
check out the links below
Free Student Version of CircuitLogix
ExpressPCB - Free PCB layout and schematic software
Kicad
FreePCB: freeware PCB layout software
what do you think ?? better and free AutoCAD
arpanmukherjee1 is offline   Reply With Quote
Old 06-05-2011, 03:04 PM   #7 (permalink)
abhidev's Avatar
Use Vizio...it has some nice options...also there is another free software named 'EAGAL'....
Core 2 duo E4500 2.2gHz , ASUS P5GCMX , 3GB Transcend , Corsair VX 550w, MSI R5770 HAWK Edition 1GB, CM HAF-922, LG W2243T 21.5" LCD, I-Ball Baton
abhidev is offline   Reply With Quote
Old 06-05-2011, 11:17 PM   #8 (permalink)
A PC GAMER
Gaurav265's Avatar
Talking Re: need help about softwares important !
Thanks for advice now i can start writing.i try all and find which is beter.
Gaurav singh
Old 07-05-2011, 04:47 PM   #9 (permalink)
Your Ad here
nisargshah95's Avatar
Thumbs up Re: need help about softwares important !
Or else what I suggest (might sound weird too) is that you use Paint for all your notes altogether. It will help you draw rough images and has the 'Text' option so you can write anywhere. Plus it will save your notes in images so you'll not have to worry about the compatibility problems when you open notes in another PC.
“The Web is like a dominatrix. Everywhere I turn, I see little buttons ordering me to Submit.”
ASUS P5KPL AM/PS | P4 @ 3.07GHz | Ubuntu 11.04 / Win Server 2k8 / XP SP3 | 1GB DDR2 | Samsung HD080HJ 80GB
nisargshah95 is offline   Reply With Quote
Old 08-05-2011, 01:42 PM   #10 (permalink)
abhidev's Avatar
Also if you use paint....then you won't be able to even edit any of your notes later...how good is that???
Old 12-05-2011, 04:52 PM   #11 (permalink)
Your Ad here
When will the eraser tool come in use
Old 12-05-2011, 09:12 PM   #12 (permalink)
Stuck in Time...
Vyom's Avatar
I will have to agree with abhidev with this one! Paint would just be a BAD idea for this kind of work!
Marty: Hey, Doc, we better back up. We don't have enough road to get up to 88.
Doc Brown: Roads? Where we're going, we don't need, "roads!" :)
──── On the Internet you can be Anything you want. It's Strange that, so many people choose to be Stupid! ────
Vyom is offline   Reply With Quote
Old 12-05-2011, 09:36 PM   #13 (permalink)
Your Ad here
I don't think there would be any kinda problem with the eraser tool. It just works perfect.
Plus Paint will be easier to use than other softwares which have lot of options and some even come for a price.
Old 12-05-2011, 09:53 PM   #14 (permalink)
Stuck in Time...
Vyom's Avatar
Man! When I read this comment of yours, "When will the eraser tool come in use ", I was hoping you said it as a irony. But I guess, I was wrong!
Believe me, I am much of an advocate myself, when it comes to praise the simplicity of Paint program of windows. I use it myself to edit and tweak many images. But that's where the task of Paint Ends!
Paint is good as long as one just need to tweak things a bit, or have to edit some loose ends of a static image. But believe me when I say, to Create Something from Scratch, Paint would be a Pain in the bottom side, and that too is just a vastly underestimation!
Few drawbacks of Paint with respect to the kind of work OP wants:
  • Inability to modify electronic components.
  • Inability to reuse portions of one diagram into another.
  • Inability to change the labels, once it's set. That is some major drawback. The text feature of Paint, is I think, its weakest aspect.
  • Coloring the diagram would be a hassle that I would turn the project a nightmare to complete!
  • OP would have two options to save the image, as a bmp, which would take A LOT of space, but can be edited easily later. And another is format like .jpg, which takes VERY LESS space, but would tarnish the image beyond any chances of modification!
Need I say more!
Bonus tip: PNG format is the best format to save such drawings in paint.
Old 12-05-2011, 10:13 PM   #15 (permalink)
Your Ad here
LOL. Okay, I give up. Thanks for pointing those things out...
Old 13-05-2011, 07:45 AM   #16 (permalink)
A PC GAMER
Gaurav265's Avatar
paint is also beter for some but not all.
"WHY SO SERIOUS ?"
