Re: problem after formatting pc
Originally Posted by sunny10
i am using xp and he does not want to format the drive but open it as it contains some documents.
control panel >folder options >Show system files , hidden files
go to D:\
u will see a file called autorun.inf
Delete that file
Reboot pc
edit
next time dont forget to install Good AV +Firewall and update it weekly
AMD Phenom II X6 1055T ,Benq G2220HD 22 ,GIGABYTE GA-880GM-UD2H ,COOLER MASTER Elite 310 ,CORSAIR 2GB 240-Pin DDR3 X3[6GB] , FSP Saga II 500 W HD 5750 . Hyper 212+ OS :Win 7 64 bit
