Old 04-05-2011, 09:29 AM   #1 (permalink)
XLr8
arpanmukherjee1's Avatar
Default Remote PC controller. choosing the right freeware
hi, i want a software (freeware) that can have total control over client PC's over LAN
that includes desktop sharing, file transfer, network sharing etc...
the computers to connect are my netbook as server and 3 other PCs as clients (see config in siggy, all PC are more or less the same)
(netbook running XP Home and clients win7+win7/ubuntu+XP )
initially started with desktop sharing in which ScreenStream did not perform well.
used UltraVNC and TeamViewer but dont know what i am doing wrong as connection cannot be established. networking and workgroup comps are working fine.
not much experienced network guy, so if somebody could point out some tutorial, that would be nice
arpanmukherjee1 is offline   Reply With Quote
Old 04-05-2011, 09:49 AM   #2 (permalink)
BIOS Terminator
nims11's Avatar
Default Re: Remote PC controller. choosing the right freeware
i use teamviewer to control my PC in LAN whose monitor is not working. here is what i did-
1. after installing teamviewer in computer, goto option and under general tab- change "accept incoming LAN connections" to "accept". check "start teamviewer with windows" option if not enabled.
2. under security tab- set a permanent password
3. i also had to enable the window logon option under "security" as there was no monitor and i had to control right from the windows login screen. you can also do this if you dont want to go and log into the computers you want to control.
repeat step 1,2,3 for all computers you will be connecting to.
4. after doing this in all the computers you want to control, open teamviewer in the computer through which you will be controlling all the other computers. in the partner ID, enter the LAN IP of that computer, connect to partner, and then enter the password you had set in the "permanent password" in that computer you are connecting to.
i hope it helps!! all the best
PS: if it works, its my first tutorial!!
nims11 is offline   Reply With Quote
Old 04-05-2011, 03:44 PM   #3 (permalink)
XLr8
^^ thanks. will try it out at night and post the results.
Old 04-05-2011, 04:32 PM   #4 (permalink)
Yup, Team Viewer is the best.
No other freeware is more good.
Old 04-05-2011, 05:53 PM   #5 (permalink)
Do you see team viewer ready to establish connection or not.Check the bottom left corner if there is a tick symbol then its ok otherwise there is a problem in your network connection. BTW how are you trying to connect them? wired or wireless (as you are using netbook) there could be a glitch in the router connection if possible.
Abhinav
abhinav_sinha is offline   Reply With Quote
Old 04-05-2011, 08:28 PM   #6 (permalink)
Stuck in Time...
Vyom's Avatar
I use TeamViewer to connect my office PC, so that I can complete work from home, which are pending.
But didn't knew that it had so many features as described by nims11.
Marty: Hey, Doc, we better back up. We don't have enough road to get up to 88.
Doc Brown: Roads? Where we're going, we don't need, "roads!" :)
──── On the Internet you can be Anything you want. It's Strange that, so many people choose to be Stupid! ────
Vyom is offline   Reply With Quote
Old 04-05-2011, 09:09 PM   #7 (permalink)
Sami Hyypiä, LFC legend
Liverpool_fan's Avatar
Use any VNC Server/Client combo. Make sure the firewall is not blocking the connections.
Liverpool_fan is offline   Reply With Quote
Old 04-05-2011, 10:05 PM   #8 (permalink)
XLr8
TeamViewer not able to access the network. i can connect to internet but teamviewer does not detect network.
BTW its all wired
just discovered another problem ::
cannot login to 192.168.1.1 with us:admin pw:admin. the router is sterlite sam300AX by MTNL.
this is INSANE !!!!!!
dont know whats going on !!!!!!!
Old 05-05-2011, 06:13 AM   #9 (permalink)
BIOS Terminator
nims11's Avatar
can you successfully ping other computers?
Old 05-05-2011, 07:51 AM   #10 (permalink)
You mean you don't see a tick in the bottom left corner.
I assume you have accessed it earlier and not able to do now and you haven't made any changes. See if there is a hard reset button to restore it to factory setting press it. Then reconfigure it to proper one. Be sure to configure it correctly else you won't be able to connect to internet.
Abhinav
Old 05-05-2011, 09:02 AM   #11 (permalink)
XLr8
yes. all comps are present
no i dont
yes, i have done that. i forwarded one port 192.168.1.107:2107.
now i cant ping to it, all setting are gone.
without login i cannot alter any settings.
reset dosent change things
again, internet is working fine
trying to reset network and reinstall teamviewer.
same problem.
untill i log into my router how can i know what are the current settings??
what ip/ports are open ??
Old 05-05-2011, 09:34 AM   #12 (permalink)
Try turning off the firewall or keep team viewer in exception
Old 06-05-2011, 09:06 PM   #13 (permalink)
XLr8
IT WORKED !!!!!!!!
dont know how !!
was it the reinstall ??
i followed nims11 steps first time as well as the second time.
dont know what changed !!!
also to take matters entirely in my netbook's hand i downloaded this
TeamViewer does not support sound sharing. is anything to do it ??
found this. but it is paid..
any s/w that can send the audio out to remote address ??
Old 06-05-2011, 09:27 PM   #14 (permalink)
BIOS Terminator
nims11's Avatar
this looks nice-
SpeakerShare – A Simple Cross-Platform Alternative to AirFoil | Squeeze Box
here is a winamp sound server plugin (not sure if this will work) - Cool remote sound server for Winamp - Winamp
pulseaudio(FLOSS sound server) - PulseAudio - Wikipedia, the free encyclopedia
tell us if it works!!
Old 07-05-2011, 07:44 AM   #15 (permalink)
XLr8
^^ thanks will try it in the evening.
one more thing.
can somebody tell me how to use teamviewer over the internet ???
that would be helpful ...
Old 07-05-2011, 09:52 AM   #16 (permalink)
This Google search has lots of links to help you to use it over the internet
how to use teamviewer over internet - Google Search
Old 11-05-2011, 09:38 AM   #17 (permalink)
I have used it via internet while I was in banglore to control my pc at home. Its just that both should have internet connected, team viewer on and you must know the id and password.It also depends on the internet speed specially if you are trying to exchange files.
Abhinav
Old 11-05-2011, 11:22 AM   #18 (permalink)
XLr8
yeah.. figured out pretty much every option available
downloaded teamviewer QS
created an account and added 3 computers, so i dont have to remember the pwd.
on 1 MB/s connection and resolution of 1600x900 is buffered slowly, so decreased the res.
also the router issue is solved. turns out MTNL had changed their us & pwd to 'mtnlbroadband'
OK. all in all ThankYou every body who participated in this discussion
Mods: this thread is ready to be [CLOSED]...
