Old 28-04-2011, 08:07 PM   #1 (permalink)
Exclamation OS Installation Problem
Friends, Need your support, one more time.
I recently bought an Dell Inspiron N5010 Laptop (w/o Operating System) and I am trying to install Windows 7 (which again new) onto the Laptop but I'm unable to install the Windows.
The Windows DVD is working fine on my local machine but does not work on the Laptop. Also, the compatibility is not the issue.
The Error message is "Windows cannot install required files. The files may be corrupt or missing. Make sure all files required for installation are avilable and restart the installation".
As per my understanding the System is not able to write on HDD. Request your support.
Thanks and Regards,
Prathamesh R. Tawde
prathamtawde is offline   Reply With Quote
Old 28-04-2011, 08:21 PM   #2 (permalink)
Stuck in Time...
Vyom's Avatar
Default Re: OS Installation Problem
Are you sure, the installation media is fine? Try to copy the entire contents of DVD to another system in a folder.
Then report if any error occurs.
Marty: Hey, Doc, we better back up. We don't have enough road to get up to 88.
Doc Brown: Roads? Where we're going, we don't need, "roads!" :)
──── On the Internet you can be Anything you want. It's Strange that, so many people choose to be Stupid! ────
Vyom is offline   Reply With Quote
Old 28-04-2011, 08:29 PM   #3 (permalink)
Simply a DIGITian
krishnandu.sarkar's Avatar
Yup, it looks like your media is corrupt.
I won't suggest to copy that DVD, rather download a fresh one. As you have the legit keys it won't be a problem. And download it from Microsoft's site.
  • Read The Forum RULES First.
  • Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
  • Before Starting A New Thread Read The STICKY THREADS First
  • Before Participating In Bazaar Section Read The BAZAAR RULES
krishnandu.sarkar is offline   Reply With Quote
Old 28-04-2011, 08:34 PM   #4 (permalink)
Stuck in Time...
Vyom's Avatar
^^ But I would have still preferred to try to copy the content to another system. This way I could be sure, if the DVD reader of my laptop isn't the culprit. And if it is, then it would stop me from hassle and wait to d/w a file of GBs!
Old 29-04-2011, 08:59 AM   #5 (permalink)
Your Ad here
nisargshah95's Avatar
Yeah. And it's not a question of piracy if he uses the files himself without giving to anyone.
“The Web is like a dominatrix. Everywhere I turn, I see little buttons ordering me to Submit.”
ASUS P5KPL AM/PS | P4 @ 3.07GHz | Ubuntu 11.04 / Win Server 2k8 / XP SP3 | 1GB DDR2 | Samsung HD080HJ 80GB
nisargshah95 is offline   Reply With Quote
Old 29-04-2011, 12:23 PM   #6 (permalink)
Fullbring
Zangetsu's Avatar
@prathamtawde: I guess DOS is preinstalled in the laptop...
& to install windows 7 u have to do some changes in BIOS setting mainly in HDD settings...
Old 29-04-2011, 09:16 PM   #7 (permalink)
I think the problem is with ur memory, i think that the file to be written on the HDD is not being written on ur memory(RAM) properly, and here the problem starts ...
and too check for ur BIOS settings and try different OS system, and ur laptop is new so i dont think there is any mess with ur hardware !!!
Dewey is offline   Reply With Quote
Old 30-04-2011, 05:13 PM   #8 (permalink)
Try to make the Dvd a .iso and use a software like WinTOflash to install Windows via Usb
Old 30-04-2011, 07:28 PM   #9 (permalink)
Stuck in Time...
Vyom's Avatar
^^ Yeah, that seems to be a good idea, if the DVD drive have problems.
But only if, the OP has not being abducted by aliens after posting this problem, would he be able to try this
Old 08-05-2011, 07:45 AM   #10 (permalink)
~ Harsh ~
hdsk.23's Avatar
there is no need to wintoflash.. Microsoft has a official tool to make usb drive win7 installer!
~Harsh~
Apple MacBook Pro 13''
Intel Core 2 Duo P8600
4Giga RAM, 500Giga Hdd.
hdsk.23 is offline   Reply With Quote
Old 08-05-2011, 10:05 AM   #11 (permalink)
Mmmph!!!
doomgiver's Avatar
that does not work!!!
it didnt work for me, m$ sux
Mmmphh-mphhhh-mmphh mhh!!!
Steam : doomgiver
doomgiver is offline   Reply With Quote
Old 08-05-2011, 12:51 PM   #12 (permalink)
Microsoft= Bloat
WintoFlash= Good use/ 5 mb only
BTW, you can do it without any software= Install Windows 7 Or Windows 8 From USB Drive/Pen Drive
Old 08-05-2011, 02:33 PM   #13 (permalink)
Electronic.
Neuron's Avatar
Installing Windows 7 from a pendrive is damn simple.Just copy the iso file into the pendrive.Use a utility like EasyBCD to make the pendrive bootable from the iso file.Keep the ctrl key pressed when the setup loads.A command prompt will appear.Then just close it and you are done.
I don't always make sense,but when I do,I don't.
Neuron is offline   Reply With Quote
Old 08-05-2011, 03:14 PM   #14 (permalink)
Mmmph!!!
doomgiver's Avatar
i meant to say that the official windows usb installation method did not work for me, of course, i used the interwebz and found a better solution.
you just have to run usb boot creator, and put the contents of the iso file in the pen drive root. and then reboot, you are done!!! no messing with the command line at all.
i agree. m$=more bloatware than good.
Steam : doomgiver
