24-04-2011, 03:56 PM
need help urgently for utorrent
I am in really BIG problem guys!!!!
plz help me.
I was downloading some files from a torrent via utorrent.
but at 92% of download, i accidentally removed the torrent from utorrent.
i have torrent in mypc, when i click on it, it starts downloading all AGAIN!!!
I don't wanna download whole files again. I have half completed files of torrent(which i removed), Is there a way to download at 92% rather than start downloading all over again>
If U mess with me, U will be HACKED!!
Get all Hacking Tips & Tricks, on www.gen-xtechcentre.webs.com
24-04-2011, 04:56 PM
RPG FTW!!!
Re: need help urgently for utorrent
Add torrent.Right click>advanced>Set download location.Point it to files already downloaded.
The truth is out there...anybody got the URL?
24-04-2011, 05:10 PM
Try this - Utorrent question
we discussed too long on it very recently in TDF.
Abhinav
25-04-2011, 10:56 AM
it told me to overwrite files..
25-04-2011, 11:13 AM
Living to Succeed
Overwrite that... it will check what parts are there and download the rest,... That is how it works for me...
Q6600+Abit IX38QuadGT+Corsair 4gb 800mhz+ Ultra 120 Extreme+ tagan 600wts+CM690
Alienware M15 - with Gforce 460 1.5gb + 8gb DDR + i7 1.73ghz
25-04-2011, 06:38 PM
are u sure? i don't wanna lose my files
25-04-2011, 06:41 PM
Fullbring
plz help me.
Yes this question was raised by me in the link abhinav has given....
& we are 100% sure the it wont start it again from 0%...
if u have fear then do backup the 92% files in safe location & try the steps given in that thread....
utorrent will not deceive u...
25-04-2011, 09:35 PM
Simply a DIGITian
Another way is after adding the torrent and setting the old path, just stop it and right click on the torrent and click Force Check, that will also verify if you are in doubt.
Though we are 100% sure the 1st method wont overwrite anything.
This is just if in case you don't believe us
- Read The Forum RULES First.
- Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
- Before Starting A New Thread Read The STICKY THREADS First
- Before Participating In Bazaar Section Read The BAZAAR RULES
26-04-2011, 10:25 AM
thanks guys for helping me  :-P
but my download was at 92%, but it after checking stuck at 35% gives me error:
Error: Data error (cyclic redundancy check).
Plz help me (again) guys!!!!
26-04-2011, 10:30 AM
Living to Succeed
I believe then the downloaded files are corrupt... Try copying the files in another location and add the torrent again for download and this time link it to the newly copied files..
26-04-2011, 10:50 AM
Fullbring
Oops then something is wrong with the files
26-04-2011, 07:53 PM
can any (Expert) Geek give me the solution of this problem
26-04-2011, 09:04 PM
Super Moderator
Which directory did you place the copied files in. Goto option>>>preferences>>directories.
Check "put new download in". The copied data has to be here.
27-04-2011, 09:26 AM
yes copied data is there, but problem is this while checking files utorrent got stuck at 35% and gives me error.
27-04-2011, 11:00 AM
Super Moderator
Then while copying pasting over there was corruption. Re-do the copy paste else re-do the whole DL.
27-04-2011, 11:46 AM
I found an expert geek who solved me problem That's Me (lol)
i thought there might be bad sectors in drive (where are my downloading files).
so i run the following command in cmd:
chkdsk (drive letter eg. E: ) /r
It solved my problem. Yipeeeee
27-04-2011, 12:40 PM
Fullbring
^^cyclic redundancy check error is related to data corruption or BadSector
27-04-2011, 06:34 PM
exactly this cmd command check for the bad sector in my downloading files and fixed them
