Old 15-04-2011, 07:58 AM   #1 (permalink)
Post directX problem..
i use windows7 and i had been playing just cause 2 but now whenever i try to run the game this error occurs :-
Fatal DirectX error!
Code: 15
Result:0x80070057: E_INVALIDARG
The game will now exit. Try running the game with /failsafe if the problem
persists.
sid_gupta is offline
Old 15-04-2011, 11:04 AM   #2 (permalink)
XLr8
arpanmukherjee1's Avatar
Default Re: directX problem..
^ did you update directX ??
arpanmukherjee1 is offline
Old 15-04-2011, 11:43 AM   #3 (permalink)
Fullbring
Zangetsu's Avatar
Code: 15
persists.
there cud be a problem with DX files in windows 7...
do a sfcscan of the system & repair windows....
Zangetsu is offline
Old 15-04-2011, 11:49 AM   #4 (permalink)
Super Moderator
asingh's Avatar
Can you tell your full system rig and OS.
asingh is offline
Old 15-04-2011, 01:00 PM   #5 (permalink)
JojoTheDragon's Avatar
Is this a duplicate thread ?
problem running just cause 2..
JojoTheDragon is offline
Old 18-04-2011, 12:25 AM   #6 (permalink)
Burning in the skies
.=Pyro=.'s Avatar
i think it needs DX 10 to run.
Waiting for the end to come......
.=Pyro=. is offline
Old 18-04-2011, 06:22 AM   #7 (permalink)
Fast 'N' Furious
topgear's Avatar
@ sid_gupta - you have created two duplicate threads of the following thread ( link mentioned below ) even after one of your duplicate thread was deleted by mod - consider this as the final warning and if you made another duplicate thread of this topic I will take action against you.
Duplicate thread - continue the discussion over here.
ToPsPeEeD = FaSt BuT StEaDy
topgear is online now
