Old 11-04-2011, 03:22 PM   #1 (permalink)
annindyadas's Avatar
Default firefox problem
guys many a times whn i m surfing the net my browser reddirects to westbyte.com. i don't knw what problem is this . i have used many antiviruses to remove the adware but none of them does gud except for norton which removes it but after sometimes it again reappear. is there any way to remove it manually or permanently!plsss help
Windows 7 Ultimate 64-bit SP-1
Core i5 750@2.6Ghz
4x2Gb ddr3@1333Mhz
Ati HD 5770 1Gb ddr5
1 TB Seagate HDD
annindyadas is offline   Reply With Quote
Old 11-04-2011, 06:05 PM   #2 (permalink)
Default Re: firefox problem
Its a virus 100%
Try doing a scan using this online AV-
Click here-> HouseCall - Free Online Virus Scan - Trend Micro USA
Also install Spybot Search&Destroy and click "immunize" after you update it.
Old 11-04-2011, 06:12 PM   #3 (permalink)
Living to Play
gameranand's Avatar
Well uninstall Firefox or ant browser and then scan your PC then install them again. Maube this could help. Also try Avast boot time scan for this bit(h.
In war, Victory. In peace, Vigilance. In death, Sacrifice.
Using TDF through mobile. Digit optimized this forum for mobiles. Works nicely YAY :D:D
gameranand is offline   Reply With Quote
Old 15-04-2011, 09:37 PM   #4 (permalink)
Yeah tried all anti virus but nt any spyware but only av detects is norton but it does removes it but aftr sometimes it again reappear
Core i5 750@2.6Ghz
4x2Gb ddr3@1333Mhz
1 TB Seagate HDD
Old 15-04-2011, 09:43 PM   #5 (permalink)
shruti's Avatar
try scanning your pc. also delete your current firefox profile and create a new one.
shruti is offline   Reply With Quote
Old 16-04-2011, 12:00 PM   #6 (permalink)
Anish's Avatar
better option is to unistall firefox completely, run a registry cleaning using ccleaner of something and then install firefox 4. Is it fixed?
The secret ingredient is nothing
Anish is offline   Reply With Quote
Old 18-04-2011, 12:27 AM   #7 (permalink)
Burning in the skies
.=Pyro=.'s Avatar
its probably virus or adware. ^^ do what others are saying. you can use glary utilities to clean registry.
Waiting for the end to come......
.=Pyro=. is offline   Reply With Quote
Old 18-04-2011, 02:28 PM   #8 (permalink)
ya i have tried all above stuffs including revo uninstaller and last ithing is left is to try with ADWARE OR SPYWARE OTHERWISE i will have to format my drive
Core i5 750@2.6Ghz
4x2Gb ddr3@1333Mhz
1 TB Seagate HDD
Old 18-04-2011, 02:38 PM   #9 (permalink)
1. Uninstall Firefox completely
2. Delete all the temporary files.
3. Search and delete if there is a folder named "Mozilla Firefox"
4. Clean your registry files with Ccleaner.
5. After all this scan your drive with a good antivirus.
6. Download a new Firefox again and install Firefox
If the problem still exists then your idea is good format you drive.
rajeevk is offline   Reply With Quote
Old 18-04-2011, 02:40 PM   #10 (permalink)
God of Mistakes...
Garbage's Avatar
If nothing is working, best way is to format the windows installation completely and reinstall.
Registered Linux User #468778
http://twitter.com/_Garbage_
Garbage is offline   Reply With Quote
Old 18-04-2011, 02:59 PM   #11 (permalink)
Fullbring
Zangetsu's Avatar
cud u give an example when it happens.
Btw Westbyte is official website of IDA.so u must have installed IDA along wid the toolbar.
just uninstal the toolbar from add/remove programs
I cant see any toolbar of it in your browser.
Old 21-04-2011, 03:22 PM   #12 (permalink)
whn m sufging facebook or digit site or any othr sites suddenly it redirects saying(in pic
) and next thing i see is westbyte site
Core i5 750@2.6Ghz
4x2Gb ddr3@1333Mhz
1 TB Seagate HDD
Old 21-04-2011, 04:17 PM   #13 (permalink)
Living to Play
gameranand's Avatar
Bro didn't everyone here told you that its a virus problem and you have to scan your PC for viruses and if there is no good in that then you have to reinstall your OS.
Old 21-04-2011, 09:36 PM   #14 (permalink)
Simply a DIGITian
krishnandu.sarkar's Avatar
If no antivirus is able to remove the virus, then before formatting you may want to try out the online scanners and see if they can help you.
Otherwise go for Reinstall
  • Read The Forum RULES First.
  • Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
  • Before Starting A New Thread Read The STICKY THREADS First
  • Before Participating In Bazaar Section Read The BAZAAR RULES
krishnandu.sarkar is offline   Reply With Quote
Old 21-04-2011, 09:42 PM   #15 (permalink)
Electronic.
Neuron's Avatar
Try this.
I don't always make sense,but when I do,I don't.
Neuron is offline   Reply With Quote
Old 23-04-2011, 03:11 PM   #16 (permalink)
Well, you got two things left to do...
1) Download MalwareBytes Anti Malware (from some other computer or a different browser) and run a full system scan and remove all the Viruses
2) Reinstall Firefox using Revo Uninstaller to uninstall it. After that, if the error still persists, you better reinstall your whole windows.
abhilashr is offline   Reply With Quote
Old 23-04-2011, 03:39 PM   #17 (permalink)
Linux Noob
Dangerous Dave's Avatar
reinstall the windows..... it will be best
My Speed http://www.speedtest.net/result/1033703140.png
Dangerous Dave is offline   Reply With Quote
Old 25-04-2011, 09:21 AM   #18 (permalink)
guys thanks for ur replies but recently aftr installing zonealarm trial it didn't redirectd me to the site till now even though it didn't showed any threat !it's like 1 week!!!!!!!!
Core i5 750@2.6Ghz
4x2Gb ddr3@1333Mhz
1 TB Seagate HDD
Old 25-04-2011, 09:29 AM   #19 (permalink)
Download and instal Malware Bytes Antimalware. Do scan with that.
Many infections will show up.
Old 25-04-2011, 10:34 AM   #20 (permalink)
Mmmph!!!
doomgiver's Avatar
maybe the hosts file is changed/infected?
Mmmphh-mphhhh-mmphh mhh!!!
Steam : doomgiver
doomgiver is offline   Reply With Quote
