Old 25-03-2011, 10:01 PM   #1 (permalink)
mohityadavx's Avatar
Default Firefox Problem
I have been suffering this problem in firefox since a long a time. Whenever I try to download a file it stops on its own like firefox would show downloading at x kbps but there would be no progress going on in real time and to cure this i will press pause and then press play again . I am really frustrated about this I used firefox 3.6.15 since i first encountered this problem. Yes i have taken the obvious step and updated the firefox to firefox 4.0
XPS 15 | Infibeam Pi |LG P500 |GoGear SA52XX | Sony PS2 | Sony H55 | Sennheiser CX 180 , MX760
For Free Legal Documentation - Rent Agreement/RTI etc
KAGZAAT
www.bleedlaw.com For Law student & aspirant
mohityadavx is offline   Reply With Quote
Old 26-03-2011, 12:17 AM   #2 (permalink)
ithehappy's Avatar
Default Re: Firefox Problem
That ain't browser issue, may be your ISP, duuno, have you tried another browser?
i7 950SABERTOOTH8GB RAMGTX560690II +TX650
SGS II
ithehappy is online now   Reply With Quote
Old 26-03-2011, 12:24 AM   #3 (permalink)
XLr8
arpanmukherjee1's Avatar
is uTorrent or other program running ??
you can download : NetBalancer - internet traffic control and monitoring tool
check traffic of processes. give firefox the highest priority.
if that fails, install other browser, e.g Opera, see if the problem persists.
if yes maybe your router has gone haywire. try changing the ports
arpanmukherjee1 is offline   Reply With Quote
Old 02-04-2011, 12:46 AM   #4 (permalink)
aswin1's Avatar
Try firefox addon Downthemall
aswin1 is offline   Reply With Quote
Old 02-04-2011, 07:59 AM   #5 (permalink)
This happens with me too. Why not use a separate browser just to download?
Copy paste download link into Internet Explorer and click download.
Try using latest Firefox.
This is most probably ISP's problem and not browser.
Do you have any other software using net when you download?
Old 03-04-2011, 08:34 AM   #6 (permalink)
Living to Play
gameranand's Avatar
What is your internet plan because if you use from from mobile then it will occur mostly in other case use opera for downloading.
In war, Victory. In peace, Vigilance. In death, Sacrifice.
Using TDF through mobile. Digit optimized this forum for mobiles. Works nicely YAY :D:D
gameranand is offline   Reply With Quote
Old 03-04-2011, 01:16 PM   #7 (permalink)
^^ its reliance 300kbps so what i have concluded is it is a probelm with f reliance only
KAGZAAT
Old 03-04-2011, 01:22 PM   #8 (permalink)
^^ Yup, its safe to assume it.
Contack Relaince about this.
Old 03-04-2011, 04:30 PM   #9 (permalink)
Living to Play
gameranand's Avatar
Maybe. Be sure to first install firefox clean without any add ons whatsoever and check and also check this with other browser if this problem persists with every browser then its the fault on your ISP part.
Old 03-04-2011, 11:34 PM   #10 (permalink)
XLr8
facing a new prob with FF.
page loads elements are rendered and then stops automatically and every thing clears out
Old 04-04-2011, 08:35 AM   #11 (permalink)
@arpan
Its probably due to slow connection. Please do speed test and post results.
Try using Internet Explorer and see if its having same error.
Google Chrome is best browser no so I also reccomend you to use that.
