LinkBack (3) Thread Tools Display Modes
Old 19-03-2011, 03:04 PM   3 links from elsewhere to this Post. Click to view. #1 (permalink)
Exclamation Folder lock : Unlock problem
Hi i had locked one of my folder with folder lock s/w
y'day i formated my pc coz of some virus and reinstall windows xp
now my that locked folder is not unlocking
i chked a thread related to that problem but i couldnt understand wat to do??
I m attaching a screen shot of directory files in cmd prompt
the name of file which is locked is ani
plz help me to unlock that folder !
Thanks
anni
ANNI4 is offline   Reply With Quote
Old 20-03-2011, 07:23 PM   #2 (permalink)
Question Re: Folder lock : Unlock problem
plz help asap
Old 20-03-2011, 08:24 PM   #3 (permalink)
Your Ad here
nisargshah95's Avatar
Default Re: Folder lock : Unlock problem
Try re-installig the software and then unlocking the folder.
“The Web is like a dominatrix. Everywhere I turn, I see little buttons ordering me to Submit.”
ASUS P5KPL AM/PS | P4 @ 3.07GHz | Ubuntu 11.04 / Win Server 2k8 / XP SP3 | 1GB DDR2 | Samsung HD080HJ 80GB
nisargshah95 is offline   Reply With Quote
Old 20-03-2011, 09:01 PM   #4 (permalink)
Exclamation Re: Folder lock : Unlock problem
i did that but its not helping....
Old 20-03-2011, 10:47 PM   #5 (permalink)
Stuck in Time...
Vyom's Avatar
It maybe your lucky day. Cause as far as I know, you can solve this problem by just a rename command.
Try the following command in your command prompt, when you are in the E: drive...
ren aNI.{21EC2020-3AEA-1069-A2DD-08002B30309D} aNI
Marty: Hey, Doc, we better back up. We don't have enough road to get up to 88.
Doc Brown: Roads? Where we're going, we don't need, "roads!" :)
──── On the Internet you can be Anything you want. It's Strange that, so many people choose to be Stupid! ────
Vyom is offline   Reply With Quote
Old 21-03-2011, 06:41 PM   #6 (permalink)
Thumbs up Re: Folder lock : Unlock problem
Hey Vineet.... Thanks! Thanks a Lot yaar!!! u solved my problem
Old 21-03-2011, 08:29 PM   #7 (permalink)
Stuck in Time...
Vyom's Avatar
Glad that I was able to solve this problem.
That Folder lock which you used, uses one of the simplest method of locking a folder. The theory behind it is that, if a folder is renamed, with the extension of a Command Line Switch (CLSID) of proper entities of windows like, My Computer, My Documents, Control Panel, etc, then instead of opening the original folder, it will open that entity of which CLSID is of.
So, if I rename a folder to folder.{20D04FE0-3AEA-1069-A2D8-08002B30309D} then that folder will now point to My Computer. Since 20D04FE0-3AEA-1069-A2D8-08002B30309D is the CLSID of My Computer.
For furthur info and more CLSID:
Command Line Switches to Display Special Objects or Folders When Opening Windows Explorer » My Digital Life
A little gyan doesn't harm anyone
Old 21-03-2011, 09:16 PM   #8 (permalink)
XLr8
arpanmukherjee1's Avatar
did that once to a friends computer. he had challanged me to open the folder. he put 10 digit password
then they said i was a H4(|{3R !!!!!! LOL how dumb !!!!!!
(BTW i dont come anywhere them)
arpanmukherjee1 is offline   Reply With Quote
Old 23-03-2011, 10:45 AM   #9 (permalink)
Your Ad here
Thanks dude! Got something useful to learn today!!! Great trick man!
Old 23-03-2011, 11:48 AM   #10 (permalink)
Stuck in Time...
Vyom's Avatar
Pleasure is all mine pal...
And Yeah... Great trick.. that is, unless of course, ony if, someone don't know about CLSID stuff
Old 26-03-2011, 05:06 PM   #11 (permalink)
R2K
In the Zone
R2K's Avatar
BTW what was in that folder?
Acer Aspire 4930G laptop- Core 2 Duo T5800 3GB ram, 320GB+LG XG1(2TB),nVIDIA 9300GS 256MB,FingerPrint Scanner,HDMI, 802.11a/b/g/Draft N Wifi
Sony Ericsson Xperia Arc S (Gloss Black)
R2K is offline   Reply With Quote
Old 27-03-2011, 03:37 PM   #12 (permalink)
am·nesiac's Avatar
I am sure some more folders and files!
am·nesiac is offline   Reply With Quote
Old 27-03-2011, 04:21 PM   #13 (permalink)
@vineet369
How did you find out the CLSID of his folder ?
EDIT: Okay. Got it. From the screeenshot.
I'll have to try this sometime.
pauldmps is offline   Reply With Quote
Old 27-03-2011, 05:19 PM   #14 (permalink)
Stuck in Time...
Vyom's Avatar
I guess something very important, since the effort to get those, made him specially to join this forum!
Originally Posted by pauldmps View Post
@vineet369
Yeah.. its fun stuff! Just don't mess with some important folder.
btw, guys.. this was my 300th Post.... thanks all of you...
Old 27-03-2011, 06:43 PM   #15 (permalink)
@vineet: Congratulations! I suppose you just became more than twice as old as the oldest person on earth.(just kidding!)
Although great trick. I had to go through all various troubles before now to do this for others.(like via linux etc.).
Personally I don't do this until absolutely necessary. I rather prefer to hide them with names such that no one guesses.
you see if you don't know its there and can't take the trouble to hunt down most probably you wont get it .(I assume Probability<1 of course as Murphy law states:"If you perceive that there are four possible ways in which something can go wrong, and circumvent these, then a fifth way, unprepared for, will promptly develop")
Abhinav
abhinav_sinha is offline   Reply With Quote
Old 27-03-2011, 07:24 PM   #16 (permalink)
Stuck in Time...
Vyom's Avatar
I still hide my *ahem* contents in a hidden folder with strange name, inside another folder of strange name, that no one would be interested to go into. But this I do, only in home, where there are no "curious minds".
But in office, I still prefer to use a small utility, like, "Folder Lock". Through which I can right click a folder and select "Lock". Which couldn't then be unlocked w/o a master password. (But this folder lock works different from how OP's folder lock used to).
So, you see, different mechanisms of hiding contents at different places apply. Maybe sometime in future, I start to store data in Encrypted format, through various 3rd party utilities. But as of now, I am happy with the degree of privacy I use.
PS: Nice Murphy law that is. And absolutely correct.
Old 27-03-2011, 10:58 PM   #17 (permalink)
@vineet:Actually the base problem in this thread was on a personal pc that's why I suggested.
Actually if one tries to make things more secure by complex procedure on portable things in most cases they won't be using it and here locking or encryption help making things simple and secure enough for open>>use>>lock.
Thanks!
Abhinav
Old 23-06-2011, 05:44 PM   #18 (permalink)
my system is windows 7, i face a very big problem, i lock a folder by 'Folder lock' software. but in the locker folder there are no file is lock,password is correct but i can't unlock the folder, when i open that folder say me access denied, plz help
Lenovo,
processor:intel pentrium dual cpu T3400 @2.16GHz
RAM 1GB
SSTEM TYPE: 32 BIT OPERTING SYSTEM
Last edited by dipankardutta44; 23-06-2011 at 06:35 PM. Reason: DETAILS OF MY SYSTEM
dipankardutta44 is offline   Reply With Quote
Old 23-06-2011, 06:17 PM   #19 (permalink)
R2K
In the Zone
R2K's Avatar
Explain the problem properly
@To all others who run into the same problem (mentioned in the first post) in future can use this as an alternative fix (after trying vineet369's method )
You can use 7-zip to open these kinda hidden folders made by those simple Folder lock batch files
Just browse to the location of the hidden folder with 7 zip ->right click->open folder ...
Voila.... your treasure chest is wide open in front of you
Old 23-06-2011, 06:53 PM   #20 (permalink)
my system:
Lenovo,
RAM 1GB
SYSTEM TYPE: 32 BIT OPERTING SYSTEM
OPERTING SYSTEM WINDOWS 7
but in the locker folder is empty
Old 23-06-2011, 09:49 PM   #21 (permalink)
Stuck in Time...
Vyom's Avatar
@R2K: Hmmmm... looks a nice solution. Will try it, if ever get stuck.
@dipankardutta44: So have you tried the methods described in this thread, and also the one mentioned just before your post by R2K?
LinkBack to this Thread: http://www.thinkdigit.com/forum/software-q/138210-folder-lock-unlock-problem.html
Thread Folder Lock 6 encrypt problem | Flashback Forum | Yttrandefrihet på riktigt! | BoardReader This thread Refback 12-08-2011 06:50 PM
Command Line Switches to Display Special Objects or Folders When Opening Windows Explorer « My Digital Life This thread Refback 13-05-2011 11:55 AM
Command Line Switches to Display Special Objects or Folders When Opening Windows Explorer » My Digital Life This thread Refback 23-03-2011 10:55 AM
- by chris
