LinkBack (3) Thread Tools Display Modes
Old 17-03-2011, 09:24 PM   3 links from elsewhere to this Post. Click to view. #1 (permalink)
shohita's Avatar
Unhappy advice for sony vaio ... please help
hello everyone ,
i own a sony vaio E series model no. VPCEB26FG.
now the problem is that when i bought it i didnt make the recovery CD , and also was foolish enough to not make partitions so i have a 500 GB c drive ( i know ...... sounds stupid)
15 days ago my kaspersky key got blacklisted and there was no antivirus in my laptop for a week .
I think theres a virus , and also the speed of my laptop is slow , i tried system restore but i dont think that worked . I scanned the system with avira antivirus and MS security essentials but they didnt detect anything .
Now i am thinking of formatting it and doing a fresh install but since i dont have a recovery CD will i lose all the bundled VAIO softwares i got ? I didnt find them on sony esupport
Please help , should i format it or try a boot scan with avast ?
shohita is offline   Reply With Quote
Old 18-03-2011, 08:40 PM   #2 (permalink)
D@rekills4's Avatar
Default Re: advice for sony vaio ... please help
Originally Posted by shohita View Post
hello everyone ,
Boot scan with Avast!, if still no luck then there is no choice but to say good bye to your bundled softwares....
D@rekills4 is offline   Reply With Quote
Old 19-03-2011, 12:15 AM   #3 (permalink)
shohita's Avatar
is there no way i can take a backup of those softwares ? someone please help
Old 19-03-2011, 07:57 AM   #4 (permalink)
Aren't those softwares available on Sony's website ? In that case, just download them from there. Most softwares that Sony bundles with their laptops are bloatwares, anyways.
pauldmps is offline   Reply With Quote
Old 19-03-2011, 08:14 AM   #5 (permalink)
See whether they are available here or not: VPCEB26FG : Downloads : Support : Sony India
lesson learned.
yup, this is true.
Old 19-03-2011, 10:39 AM   #6 (permalink)
Originally Posted by ico View Post
lesson learned.
I seriously don't understand why people pirate (or buy) antivirus software when better free alternatives are available.
Old 19-03-2011, 12:40 PM   #7 (permalink)
shohita's Avatar
@ pauldmps and ico
thanks a lot for replying
could you please suggest from where i should download win7 home premium ? And if i download it from somewhere and use the key given below my laptop then would it be same as original windows , as in , not pirated
and also please suggest me some free antivirus that doesnt have a trial version
Old 19-03-2011, 01:00 PM   #8 (permalink)
@ pauldmps and ico
I believe that it will be genuine if you use your own key. See this:Windows 7 ISO x86 and x64 Official Direct Download Links (Ultimate, Professional and Home Premium) » My Digital Life
And for AV, I'll recommend Microsoft Security Essentials. I'm using it since it was launched & it is the best light-weight AV solution.
Old 19-03-2011, 01:48 PM   #9 (permalink)
shohita's Avatar
and could you please guide me how to go about saving win 7 on a cd , should i use ashampoo or use the inbuilt software , and then how do i do a fresh install
thanks in advance you're a real saviour
Old 19-03-2011, 01:49 PM   #10 (permalink)
Note. We are not entertaining any sort of piracy here. Please avoid sharing links. If you need any help, use PM.
Better if you can call Sony Vaio people and ask them to do a fresh install for you. My friends have got it done.
Old 19-03-2011, 04:11 PM   #11 (permalink)
shohita's Avatar
sorry didnt know that deleting the post
Old 19-03-2011, 05:24 PM   #12 (permalink)
@ico
The link I have posted is completely legal as long as you use your own product key.
@shohita
Do not download Windows7 from torrents. Almost all Win7 builds available have modified or harmful code in it. Better use the link I provided & use your own key.
Old 19-03-2011, 05:24 PM   #13 (permalink)
@ico
Not talking about your link buddy. Shohita posted a PirateBay link.
Old 19-03-2011, 05:34 PM   #14 (permalink)
Super Moderator
asingh's Avatar
@ OP:
Basically you want to do a fresh install AND have a legitimate key.
1. You would have got some driver CD's with your Vaio. Do you have these.
2. Download the ISO for the M$ Win7 flavor you want.
3. Make a bootable USB using this method.
4. Validate the install using your authentic key.
5. Once you reach the desktop install all drivers from the Vaoi discs OR pull them off Sony's website.
6. Patch your Win7 via Windows Live.
This is the most we can advice you.
For an anti virus chose Avast/Avira/AVG else purchase a key.
asingh is offline   Reply With Quote
Old 19-03-2011, 08:21 PM   #15 (permalink)
shohita's Avatar
could you please tell me what is meant by ''Patch your Win7 via Windows Live''
and no i did not get any driver CDs or any other CDs with my laptop
Old 19-03-2011, 08:41 PM   #16 (permalink)
Super Moderator
asingh's Avatar
Then you will need to go to the Sony Website and download all the drivers for your specific set.
Patch Win7 = pull in all the updates which authentic (WGA certified) M$ users are eligible for. Basically you set the updates to automatic, and install what ever the www throws at you.
Old 19-03-2011, 08:49 PM   #17 (permalink)
shohita's Avatar
thanks a lot for helping me out will tell you when my problem gets solved
Old 24-03-2011, 11:37 AM   #18 (permalink)
jst visit sony vaio service center
harshit192 is offline   Reply With Quote
LinkBack to this Thread: http://www.thinkdigit.com/forum/software-q/138118-advice-sony-vaio-please-help.html
Windows 7 ISO x86 and x64 Official Direct Download Links (Ultimate, Professional and Home Premium) « My Digital Life This thread Refback 21-12-2011 08:14 PM
Windows 7 ISO x86 and x64 Official Direct Download Links (Ultimate, Professional and Home Premium) » My Digital Life This thread Refback 17-04-2011 02:17 AM
Windows 7 ISO x86 and x64 Official Direct Download Links (Ultimate, Professional and Home Premium) » My Digital Life This thread Refback 01-04-2011 12:11 AM
- by chris
