Old 13-03-2011, 02:09 PM   #1 (permalink)
mohityadavx's Avatar
Default Photoshop problem
Hi I am a newbie at photoshop ( using CS5)and basically learning it through videos at youtube. I am suffering from a strange a problem whenever i select region of photo in mask mode and then click inverse ( otherwise it select all the area except the area i want) It gives a message:-
Warning: No pixels are more than 50% selected. The selection edges will not be visible
Please Help ( I am enclosing the pic with error)
I have tried it on several pics but its not working!!!
XPS 15 | Infibeam Pi |LG P500 |GoGear SA52XX | Sony PS2 | Sony H55 | Sennheiser CX 180 , MX760
For Free Legal Documentation - Rent Agreement/RTI etc
KAGZAAT
www.bleedlaw.com For Law student & aspirant
mohityadavx is offline   Reply With Quote
Old 13-03-2011, 02:56 PM   #2 (permalink)
Mmmph!!!
doomgiver's Avatar
Default Re: Photoshop problem
try to zoom in more, and post the dimension of the image. and try to increase the tool size
Mmmphh-mphhhh-mmphh mhh!!!
Steam : doomgiver
doomgiver is offline   Reply With Quote
Old 13-03-2011, 02:57 PM   #3 (permalink)
image size is 404 x 404
tool size was 39 large enough
actually the change hue etc are working but i can't see those red ants.
KAGZAAT
Old 13-03-2011, 03:11 PM   #4 (permalink)
Mmmph!!!
doomgiver's Avatar
well, it IS making a mask, but you cannot see it. i had the same problem with the marquee tool, the trouble was that i'd set the feather option way too high, so the area was so small that the "marching ants" were not even visible at 200% zoom.
check if that is what you have done or not.
or try copying the layer and changing the color a bit, coz that image is all brown/beige.
Steam : doomgiver
Old 13-03-2011, 03:37 PM   #5 (permalink)
thanks changing the feather helped it wasn't showing it at 100%
KAGZAAT
Old 13-03-2011, 04:16 PM   #6 (permalink)
Mmmph!!!
doomgiver's Avatar
no problem. good luck!!!
Steam : doomgiver
- by chris
