Results 1 to 10 of 10
  1. #1
    Apprentice shiwa436's Avatar
    Oct 2010
    Default Need Help with these type of Viruses
    Hi guys,
    In my my system there are some .exe files, which cannot be deleted. They are not even detected by SUPERAntiSpywarePro antivirus. They are named as jfhlc.exe, jjuffe.exe
    Help me how to delete them....
  2. #2
    Nov 2008
    Kerala
    Default Re: Need Help with these type of Viruses
    Quote Originally Posted by shiwa436 View Post
    Hi guys,
    #Uninstall SUPERAntiSpywarePro antivirus then install avast and update virus def > scan full pc in safe mode
    also run spybot seach and destroy in safe mode
  3. #3
    Human Spambot thetechfreak's Avatar
    Nov 2008
    Guwahati
    To delete them manually get a software called Unlocker.
    ---------- Post added at 04:26 PM ---------- Previous post was at 04:24 PM ----------
    Link-
    Download Unlocker 1.9.0 - FileHippo.com
    oh!, forgot that manual deletion wont work.
    Use updated AV as Zangetsu has mentioned.
    Also, use Spybot Search and Destroy.
    Online antivirus might help you.
    Link-
    HouseCall - Free Online Virus Scan - Trend Micro USA
    Follow me on Twitter: http://twitter.com/wuodland
    Have a look at my Photography page: http://bit.ly/N2aMTi
  4. #4
    122.26.11.85 Zangetsu's Avatar
    Jan 2008
    Soul Society
    Hi guys,
    jfhlc.exe, jjuffe.exe are exe files created by win32 sality or win32 worms....
    if u see in hidden files & folders options disabled u will c autorun.inf...
    open this & it will have the garbage values with some *.exe file...
    so to delete dat u have to permanently delete them by using an updated antivirus (such as Avast,Avira or AVG).
    Manual deletion wont work here bcoz as soon as u refresh the page it will again appear....
    I guess SUPERAntiSpywarePro antivirus is a fake antivirus either a malware or adware
    HTC One V | Nokia 5233 | Nikon D3100 | Apple Ipod Touch 4G | Sound Magic PL21 | Sound Magic ES18
  5. #5
    Wahahaha~! Faun's Avatar
    Dec 2006
    Pune/there
    Quote Originally Posted by Zangetsu View Post
    It's just an antispyware. Not a malware.
    Steam | Flickr | Battlelog
    Asus Z68 V-Pro|i5 2500k|TRUE Black|Ripjaws X|U2311H|N560GTX Ti|D7000|Classic Vibe 50 Strat|XONAR STX|RE272|UM Miracle|Optimus G
    sam
    sam is offline
    Forum Moderator sam's Avatar
    Jan 2010
    Guwahati
    Hi guys,
    if it is Win32 sality, i doubt it'll allow you to install Antivirus. try McAfee AVERT Stinger & then install Avast. will get rid of most of the viruses.
    Quote Originally Posted by thetechfreak View Post
    unlocker will delete the file but it'll return again.
  7. #7
    Wise Old Owl Rockstar11's Avatar
    Jul 2006
    India
    1. Kaspersky antivirus
    2.Malwarebytes' Anti-Malware
    3.Combofix
  8. #8
    Oct 2010
    Thank you for all your responses...
    Quote Originally Posted by Rajesh345 View Post
    the virus is not allowing me to install avast pro antivirus.. i'am unaware of what to do..
  9. #9
    sam
    sam is offline
    Jan 2010
    Guwahati
    already replied by me. so do as i told earlier.
    Quote Originally Posted by Sam.Shab View Post
  10. #10
    Dr.gB sanoob.tv's Avatar
    May 2009
    koottanad,kerela
    use quickheal antivirus 2011.
    you can find it in the januvary issue digit's omega dvd.
    it scans before it installs.
    i had the same problem.no antivirus worked for me except quickheal.
  1. Viruses vs Anti-viruses
    By hsr in forum Fight Club
    Last Post: 10-09-2008, 11:21 AM
  2. viruses-what de do?
    By uday006 in forum Software Q&A
    Last Post: 18-08-2008, 03:29 PM
  3. How To Protect PC From Viruses?
    By VarDOS in forum Software Q&A
    Last Post: 11-07-2008, 02:13 AM
  4. plz help me about these viruses
    By yrakesh78 in forum Software Q&A
    Last Post: 13-09-2007, 02:46 PM
  5. plz help me about these viruses
    Last Post: 10-09-2007, 05:33 PM
