27-02-2011, 03:09 PM
64-bit os
can i use my 32 bit soft in 64 bit os
27-02-2011, 03:20 PM
Re: 64-bit os
The answer is yes. 98.5% 32bit software should work without any problem if you have an amd64 processor (includes Intel Core 2 Duo, Quad and Core i3/i5/i7).
But don't expect old 16bit DOS applications like Turbo C++ to work in Windows 7 64bit.
---------- Post added at 03:20 PM ---------- Previous post was at 03:18 PM ----------
Which processor do you have anyways?
27-02-2011, 03:42 PM
Re: 64-bit os
some softwares have their own 32bit as well as 64bit version. so its advised to check once before trying any software. 1 good example is Winrar.
03-03-2011, 07:41 PM
Re: 64-bit os
well i have i5 750
Windows 7 Ultimate 64-bit SP-1
Core i5 750@2.6Ghz
4x2Gb ddr3@1333Mhz
Ati HD 5770 1Gb ddr5
1 TB Seagate HDD
03-03-2011, 07:44 PM
Linux Noob
Re: 64-bit os
@ico But Adobe photoshop CS2 32 bit hangs in 64 Bit OS but Adobe Photoshop CS5 64 Bit does not hang!
My Speed http://www.speedtest.net/result/1033703140.png
03-03-2011, 07:47 PM
Re: 64-bit os
It is the time to move on from 32bit. You've named a very heavy software.
amd64 or x86-64 processors are backwards compatible with the x86 instruction set, so running most 32bit applications shouldn't be a problem.
03-03-2011, 08:21 PM
Living to Play
Re: 64-bit os
Yes. They just support 4GB ram and nowdays games recommended requirement is 4gb. also I heard that they have some problems with hard disks larger than 2.19Tb. Well that requires the mobo that supports them too but still OS is also a bottleneck.
In war, Victory. In peace, Vigilance. In death, Sacrifice.
Lost my Mobile. Will be offline for quite some time. :(
03-03-2011, 08:46 PM
Re: 64-bit os
Originally Posted by gameranand
Yes. They just support 4GB ram and nowdays games recommended requirement is 4gb. also I heard that they have some problems with hard disks larger than 2.19 gbTb. Well that requires the mobo that supports them too but still OS is also a bottleneck.
corrected your typo. also nowadays all processors & motherboard support 64bit OS.
03-03-2011, 09:17 PM
Living to Play
Re: 64-bit os
Thanks. Do you know about this 2.19Tb limitation for HDDs. Read it on Digit mag and understood most of it but not completely.
03-03-2011, 09:24 PM
Super Moderator
Re: 64-bit os
You have the soft link..?
03-03-2011, 09:44 PM
Living to Play
Re: 64-bit os
About GUID
About MBR Restrctions
---------- Post added at 09:44 PM ---------- Previous post was at 09:39 PM ----------
UEFI Limitation
04-03-2011, 12:15 PM
Re: 64-bit os
Dont you get the catch? 64 bit can use more than 4 GB RAM.
CS5 64 Bit it is optimised to use 64 bits. Cs2 32 is 32 bit.
Hence, 64 bit optimised s/w perform better in 64 bit OS.
My Photography page on- Flickr
Follow me on - Twitter
04-03-2011, 03:26 PM
Fullbring
Re: 64-bit os
yes its usable in x64 platform but the reverse is not possible
Even I had the same doubt when i was about to switch to x64 platform
