Old 26-02-2011, 06:24 PM   #1 (permalink)
100% GENUINE
Default Virus problem
I suspect my laptop is infected by virus and the anti-virus has also been made corrupt by it, my question is - now how can I clean my laptop (don't want to format and reinstall OS) and reinstall the antivirus.
OS - WINDOWS HOME SP3
just_asim is offline   Reply With Quote
Old 26-02-2011, 07:00 PM   #2 (permalink)
BIOS Terminator
nims11's Avatar
Default Re: Virus problem
try an online scanner or a boot-time scanner. An online scanner like Free ESET Online Antivirus Scanner should help. you may try some other online scanners too..
nims11 is offline   Reply With Quote
Old 26-02-2011, 07:11 PM   #3 (permalink)
100% GENUINE
Any offline suggestions...my net connection is a bit slow..so it may take hours to complete...
Old 26-02-2011, 07:22 PM   #4 (permalink)
BIOS Terminator
nims11's Avatar
online scan guarantees a scan using latest virus definition. the online scanners first downloads the definitions and then performs the scan in offline mode, so you will only require your internet connection to dwnload the scanner and the definitions. Thus, i recommend to take the pain and perform an online scan.
even if you use a boot-time scanner, i think they will also need internet connection to update their definitions.
Old 26-02-2011, 07:38 PM   #5 (permalink)
Wise Old Ghoul
Piyush's Avatar
the best option already recommended
or else u should reinstall the antivirus and update its definitions
but first option is my choice too
Steam:http://steamcommunity.com/id/alien007
"What kind of tomorrow should I dream about tonight"
--Get Backers
Piyush is offline   Reply With Quote
Old 26-02-2011, 08:34 PM   #6 (permalink)
install ComboFix & scan your system. but its a high risk software so it may do more damage then the viruses. use it only if you are sure your system is infected.
ELSE
use McAfee AVERT Stinger (7Mb, no installation) & scan your system. delete anything it finds else the virus mayn't allow the installation of A/V softwares. then install Avast! Free Edition 6 & Emsisoft Anti-Malware 5 & SuperAntiSpyware 4.
Sam is offline   Reply With Quote
Old 26-02-2011, 10:25 PM   #7 (permalink)
Anish's Avatar
Get a latest k7 total security installation disk (I mean the disk when u purchase it). Ask it for from your friends or any store, then while running the setup with the cd, it will prompt to scan your system before installing k7.. much better option if no access to online
The secret ingredient is nothing
Anish is offline   Reply With Quote
Old 27-02-2011, 10:51 AM   #8 (permalink)
100% GENUINE
Thanks! All for the valuable suggestion.
So if I'm going for online scan should I unistall my antivirus first and perform the scan or let it remain installed and perform the SCAN.
Old 27-02-2011, 11:15 AM   #9 (permalink)
Anish's Avatar
Let it be there.. you continue with your online scan
Old 27-02-2011, 02:20 PM   #10 (permalink)
Living to Play
gameranand's Avatar
Originally Posted by Sam.Shab
ComboFix
What is this thing. I mean if its a anti virus then how could it do more damage than virus and if not what is this ???
In war, Victory. In peace, Vigilance. In death, Sacrifice.
Lost my Mobile. Will be offline for quite some time. :(
gameranand is offline   Reply With Quote
Old 27-02-2011, 03:41 PM   #11 (permalink)
its a virus removal tool & it may change registry value & may edit some critical windows file. i have never used it so not very much sure.
Old 27-02-2011, 04:25 PM   #12 (permalink)
BIOS Terminator
nims11's Avatar
i used combofix long time ago when i faced the same prob and i had a dial up connection that time. didnt do any harm to me but niether it helped me.
- by chris
