Old 26-02-2011, 03:49 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Anish's Avatar
Default shutdown problem!
Hi friends,
My laptop dosent shutdown
I am using windows 7 and when i press shutdown or restart, it dosent work!! but hibernate only works..
thanks..
The secret ingredient is nothing
Anish is offline   Reply With Quote
Old 26-02-2011, 04:21 PM   #2 (permalink)
Super Moderator
asingh's Avatar
Default Re: shutdown problem!
Check the power settings.
asingh is offline   Reply With Quote
Old 26-02-2011, 11:44 PM   #3 (permalink)
Anish's Avatar
Thanks dude..
Old 04-03-2011, 03:14 PM   #4 (permalink)
Daniel Prince
Prince Sinha's Avatar
Click Start
Click Run
Enter gpedit.msc in the Open box and click OK
In the Group Policy settings window
Select User Configuration
Select Administrative Templates
Select System
and search there for your issue by enabling or disabling related setups. It may help you
Prince Sinha is offline   Reply With Quote
Old 04-03-2011, 03:22 PM   #5 (permalink)
There could be 2 problems.
---------- Post added at 03:22 PM ---------- Previous post was at 03:21 PM ----------
On topic-
You might have virus or many open applications.
My Photography page on- Flickr
Follow me on - Twitter
LinkBack to this Thread: http://www.thinkdigit.com/forum/software-q/137240-shutdown-problem.html
shutdown problem! - Digit Technology Discussion Forum This thread Refback 26-02-2011 04:54 PM
- by chris
