Old 16-02-2011, 02:42 AM   #1 (permalink)
Rising Sun!
buddyram's Avatar
Unhappy Applications are not Opening!!!
Hi folks,
My PC was working fine till yesterday morning. Later in the evening, when I switched on my PC, everything was fine till the login page from bootup. But after logging i am not able to open any application! Even it is not detecting the flash drives which i insert.
I had installed the Quick Heal Antivirus along with few Anti Spyboot to detect the malware & spywares.
Now i am not able to run those anti virus software also. I am in a total tormoil!
Please anybody would suggest me the solution!
regards
ramesh
buddyram is offline   Reply With Quote
Old 16-02-2011, 05:32 AM   #2 (permalink)
Fast 'N' Furious
topgear's Avatar
Default Re: Applications are not Opening!!!
Which OS you are using - Win7 or Winxp ?
What changes you have made before this issue occurred ?
Try using System Restore but if it fails - do a complete format of your HDD and reinstall OS again with updated drivers.
ToPsPeEeD = FaSt BuT StEaDy
topgear is online now   Reply With Quote
Old 16-02-2011, 07:40 AM   #3 (permalink)
paroh's Avatar
Scan ur computer with the bootable cd or usb with kaspersky rescue cd
Kaspersky Rescue Disk 10 Download
***********For computer related Problem PM me (If want's Doeacc A Level Project PM Me )************
paroh is offline   Reply With Quote
Old 16-02-2011, 09:49 AM   #4 (permalink)
Rising Sun!
buddyram's Avatar
HI Folk,
S I restored my PC in safe mode back to couple of days. Now it is well and fine.
ThanX topgear & Paroh
Old 16-02-2011, 06:33 PM   #5 (permalink)
1 thing- If you restore in safe mode,you can't undo it.
My Photography page on- Flickr
Follow me on - Twitter
Old 17-02-2011, 09:54 PM   #6 (permalink)
Rising Sun!
buddyram's Avatar
Wink Re: Applications are not Opening!!!
Is buying an anti-virus software or anti-spybots with full version is inevitable to protect the PC from viruses & malvares OR will the trial versions which i get thru NET or thru DIGIT will do the job?
plz revert to this
Old 18-02-2011, 03:17 AM   #7 (permalink)
^^ Free version + antispyware + little commonsense & precaution >>> paid Internet Security or Pro AVs. also remember, without updates, its Kaspersky or Calmwin. virus will enter your PC.
Sam is offline   Reply With Quote
Old 18-02-2011, 04:49 AM   #8 (permalink)
Rising Sun!
buddyram's Avatar
Thanx for the Quote Sam.Shab
Old 18-02-2011, 04:37 PM   #9 (permalink)
gkbhat.blogspot.com
plz revert to this
I think a LITTLE COMMONSENSE is enough for preventing viruses and malwares I have used Win XP connected to internet, used by many people without viruses for 2 years(1 year without reinstalling the OS) and now I have Win7 working fine for the last one and half years without a antivirus and reinstallation.
blogging at http://gkbhat.blogspot.com
gk2k is offline   Reply With Quote
Old 19-02-2011, 06:38 AM   #10 (permalink)
Fast 'N' Furious
topgear's Avatar
plz revert to this
I use this combination Avira Antivir Free+Comodo+MalwareBytes Antimalware + Regular Windows Critical/Security Updates and this combo kept me safe so far though as other's have said your role is the key factor to keep your PC free from malicious apps.
Old 19-02-2011, 07:36 PM   #11 (permalink)
Op, pls to go to a thread named 'Internet security' in freeware section. You will gain lots of AV gyaan.
- by chris
