Old 14-02-2011, 07:40 PM   #1 (permalink)
Uhu, Not Gonna Happen!
gagan007's Avatar
Exclamation Sound Problem with Media Player Classic
Media Player Classic which comes bundled along with K-Lite media codecs used to be my favorite player. But after one latest upgrade it has started behaving rather annoyingly. If any kind of movie/clip/video file is played (wait I have checked only divx (avi), mkv and mpg files only, I need to test dat (dvd) too) I can only hear the background, the music and every sound except the dialogs said by actors!!!
I have already googled it and found a couple of threads regarding this and tried to apply the solution which failed to help.
If anyone has faced similar problem and solved it please share the solution. I would love to repeat the steps.
I am now fully depending on VLC Player (I know it is the best, I just loved Media Player Classic for its ease of use, familiarity).
And thanks but no thanks, I hate KMP...It may be a great piece of software, but we don't gel along well.
My personal blog - http://gagan.scholarguru.com
gagan007 is offline   Reply With Quote
Old 14-02-2011, 07:44 PM   #2 (permalink)
Your Ad here
nisargshah95's Avatar
Default Re: Sound Problem with Media Player Classic
First completely uninstall the software and then try re-installing it. (That's the only way I could think of.)
“The Web is like a dominatrix. Everywhere I turn, I see little buttons ordering me to Submit.”
ASUS P5KPL AM/PS | P4 @ 3.07GHz | Ubuntu 11.04 / Win Server 2k8 / XP SP3 | 1GB DDR2 | Samsung HD080HJ 80GB
nisargshah95 is offline   Reply With Quote
Old 15-02-2011, 08:15 AM   #3 (permalink)
XLr8
arpanmukherjee1's Avatar
u can uninstall. install an older version. use it
and wait until next update. maybe there was a bug and will be resolved in next update
arpanmukherjee1 is offline   Reply With Quote
Old 15-02-2011, 10:16 AM   #4 (permalink)
gagan007's Avatar
thanks Nisarg, Arpan...As I do not have the older version, I will uninstall it and do a re-install
Old 15-02-2011, 03:34 PM   #5 (permalink)
try VLC Player
My Photography page on- Flickr
Follow me on - Twitter
Old 15-02-2011, 07:49 PM   #6 (permalink)
XLr8
Download K-Lite Codec Pack 6.90 (Full) - FileHippo.com
older ver available here
Old 16-02-2011, 06:00 AM   #7 (permalink)
Fast 'N' Furious
topgear's Avatar
@ gagan007 - I would suggest you to use KMP and GOM Player - they are the best IMO - you would just love them for their wide range of functionality and flexibility.
ToPsPeEeD = FaSt BuT StEaDy
topgear is online now   Reply With Quote
- by chris
