Old 14-02-2011, 06:35 PM   #1 (permalink)
Exclamation What is deep freeze software? How to uninstall Deep Freeze 6?
I have installed Deep Freeze 6 accidentally, i does not know what this software does. But after installed it, in my PC i can't Save or Delete any Data. So i can't my work. Please suggest what should i do to uninstall Deep Freeze.
Please help me!!!!!!!!!
Hardik is offline   Reply With Quote
Old 14-02-2011, 06:47 PM   #2 (permalink)
paroh's Avatar
Default Re: What is deep freeze software? How to uninstall Deep Freeze 6?
First deactivate the software on which drive or partition it is active (partition) and go to start ->all program and check it entry and uninstall it or go to control panel->Add or Remove programs and uninstall it
***********For computer related Problem PM me (If want's Doeacc A Level Project PM Me )************
paroh is offline   Reply With Quote
Old 14-02-2011, 06:54 PM   #3 (permalink)
What The.... !!!
funkysourav's Avatar
How to Uninstall Deep Freeze 6.0 Without Password | Tricks-Collections.Com
funkysourav is offline   Reply With Quote
- by chris
