Old 31-01-2011, 07:14 PM   #1 (permalink)
Unhappy Memory card problem
I have a 1 GB micro SD card which works fine on any mobile, any computer, any operating system, but not on my computer.
I have used Windows 7, open solaris, parted magic and many more operating systems to open it on my computer. It works fine on any operating system on any PC, except for mine.
I have used many memory card readers & usb ports to make it visible but it just doesn't show up.
All my memory cards work fine on my computer with same card reader and obviously same usb port, except this. Please help!!!!
Abhyuday is offline   Reply With Quote
Old 31-01-2011, 07:36 PM   #2 (permalink)
Rockstar11's Avatar
Default Re: Memory card problem
take backup all data (on other computer)and format ur SD card using mobile...
Zindagi Toofani Hai... Jahan Hai DuckBurg!
Rockstar11 is online now   Reply With Quote
Old 21-02-2011, 12:40 PM   #3 (permalink)
Amick_Madchen
Posts: n/a
What i suggest before formatting take the backup of your data otherwise your data has been lost and you need a data recovery software like Stellar, Recuva or any other third party software to recover your formatted data back.
Old 03-03-2011, 08:31 PM   #4 (permalink)
Question Still Memory card problem
I have formatted it using about tens of mobiles but no success and it has no idata left so I can do anything, even burn without hesitation.
Old 03-03-2011, 08:34 PM   #5 (permalink)
Living to Play
gameranand's Avatar
^^ If you can then reinstall the OS. My friend was facing similar problem and when he reinstalled his OS it worked fine for him.
In war, Victory. In peace, Vigilance. In death, Sacrifice.
Lost my Mobile. Will be offline for quite some time. :(
gameranand is offline   Reply With Quote
- by chris
