Old 17-01-2011, 12:22 PM   #1 (permalink)
Daniel Prince
Prince Sinha's Avatar
Exclamation CD/DVD drive
Recently, I encounter a problem.The problem is with the driver of my DVD drive.
The problems are as follows:-
1.After inserting any CD or DVD it doesn't automatically auto play even after enabling auto play from the property option.
2.Suppose at first, I enter the DVD/CD named "My Disk" and after installing the soft wares when I insert the disk named "Personal", it still keeps displaying the name "My Disk".And it only changes to "Personal" after reboot.
To solve the problem, I tried the following things:-
1.I uninstalled the DVD drive and installed it again.Then also the problem persists.
2.I fully deep scanned my hard drives using KAV 2011.Even then it prevails.
Guys, If u have also faced the similar problem and know its solution the plz, help me.
Prince Sinha is offline   Reply With Quote
Old 20-01-2011, 04:23 PM   #2 (permalink)
Default Re: CD/DVD drive
You probably have a cable problem do a scan from a an Online scanner
HouseCall - Free Online Virus Scan - Trend Micro USA
My Photography page on- Flickr
Follow me on - Twitter
- by chris
