Old 15-01-2011, 11:10 AM   #1 (permalink)
avtarkaint's Avatar
friend & master lease help me
my problem with pc is when ever i convert any video to 3gp in any converter like any video, total video etc the pc restart after 60% conversion i m fed up with that plese guide me how to sort out this problem.
thanks in advance
WBR
avtar
its winter season so heating problem will be not their and i cleaned virus 3-4 times
system:
microsoft windows XP proffesional version 2002
service pack 2, intel(r) pentium(r) 4 cpu 2.66GHz
248 MB of RAM
using- AVAST antivirus professional updated regurarly
avtarkaint is offline   Reply With Quote
Old 15-01-2011, 02:16 PM   #2 (permalink)
Default Re: strange problem
download these 2 softwares: HW Monitor
Format Factory
1. install format factory & try converting the videos.
2. if the PC restart around 60% (as you told), next time run HW Monitor & convert videos. after 40-45%, pause Format Factory & take a screenshot of HW Monitor & post it here (through imagesack).
Sam is offline   Reply With Quote
Old 15-01-2011, 09:05 PM   #3 (permalink)
XLr8
arpanmukherjee1's Avatar
@avtarkaint does comp restart while gaming etc.
also test with Prime95 (32bit) - 25.11 Download - EXTREME Overclocking
in winters overheating can be an issue
also try coverting with http://download.cnet.com/Any-Video-C...-10661456.html
arpanmukherjee1 is offline   Reply With Quote
- by chris
