Old 11-01-2011, 12:34 AM   #1 (permalink)
Default converting videos faster using hardware.
hey i recently convert videos for my mobile using the avc free. i have a gpu installed but the videos dont convert much fast. i want the converter to convert videos faster using gpu and cpu. is it possible, is there anyway i can convert videos faster. i use very high settings to convert the video?
AMD Athlon II X2 250 @ 3.01GHz,
ASUS M2N68-AM Plus Mobo,
3 GB DDR2 @ 800MHZ,
seagate 7200 500GB, WD Caviar 160GB
ASUS EAH5750 FORMULA
GIGABYTE SUPERB 460W PSU.
sasuke is offline   Reply With Quote
Old 11-01-2011, 11:54 AM   #2 (permalink)
Default Re: converting videos faster using hardware.
I dont think there is anyway
My Photography page on- Flickr
Follow me on - Twitter
Old 11-01-2011, 12:35 PM   #3 (permalink)
Fullbring
Zangetsu's Avatar
the converter will use CPU + GPU...it wont use only RAM to convert videos....
Try Any Video Converter or if u have NVidia card try BadaBoom......
& for ATI Cards ...use ATI Avivo converter
Old 11-01-2011, 03:50 PM   #4 (permalink)
^ does total video converter also use?
Old 12-01-2011, 08:09 AM   #5 (permalink)
i am using any video converter. but i thought that the graphics card can render the videos faster so converts faster
3 GB DDR2 @ 800MHZ,
Old 12-01-2011, 09:53 AM   #6 (permalink)
Fullbring
Zangetsu's Avatar
^^Use ATI Avivo converter for ATI Cards..which uses GPU
Old 12-01-2011, 11:00 AM   #7 (permalink)
^ OK..thanks!
- by chris
