Old 06-12-2010, 04:53 PM   #1 (permalink)
meem
mati17's Avatar
Default Late Display of PC Monitor
Dear Forum,
I'm facing a serious problem these days.
I have P4 Desktop with Smasung LCD Monitor.
Whenever I start my PC, the monitor power light switch turned on but no display. It will get display after 25-30 mins, and sometimes it will get 1 hour to get display of desktop screen.
Please help me out !!!
Thanks & Regards,
Matin
mat..
mati17 is offline   Reply With Quote
Old 06-12-2010, 05:35 PM   #2 (permalink)
abhidev's Avatar
Default Re: Late Display of PC Monitor
Do you have a graphics card?
Core 2 duo E4500 2.2gHz , ASUS P5GCMX , 3GB Transcend , Corsair VX 550w, MSI R5770 HAWK Edition 1GB, CM HAF-922, LG W2243T 21.5" LCD, I-Ball Baton
abhidev is offline   Reply With Quote
Old 06-12-2010, 05:47 PM   #3 (permalink)
Fullbring
Zangetsu's Avatar
@mati17: may be due to moisture.......
Old 06-12-2010, 06:30 PM   #4 (permalink)
meem
mati17's Avatar
@abhidev
Yes, I have a graphics card installed in motherboard.
mat..
- by chris
