LinkBack (3) Thread Tools Display Modes
Old 29-11-2010, 02:30 AM   3 links from elsewhere to this Post. Click to view. #1 (permalink)
evewin89's Avatar
Default W32.Ramnit worm. please help
hello guyz.......recently my pc. got infected by a virus (or spyware) known as W32.Ramnit
i scanned my computer with Norton 360 and nod32, norton detected it but its not able to remove the virus so i formatted my os partition and then reinstalled xp but then also my not able to remove the virus from my computer.
so guyz please help me to remove this virus from my computer and my pen drive.
Few sign of this virus is that....
1.whenever i connect a pen drive it creates 4 shortcut links file in that pen drive + one autorun file + one recycler folder.
i used all the methods to delete autorun.inf and other virus folder + i also tried to search a particular virus service but m still unable to kill this virus. so please help.
2. whenever i run an .exe file, it creates a new .exe file beside the original .exe file. (eg. original file.exe virus file (original fileMgr.exe)
3.The virus created a file in %program file%/Microsoft/ with the name watermark.exe
so guyz plese help me ASAP.
Evil Lives 4ever......
evewin89 is offline   Reply With Quote
Old 06-12-2010, 01:50 PM   #2 (permalink)
evewin89's Avatar
Default Re: W32.Ramnit worm. please help
I think no body in this forum encountered such a virus.
Old 06-12-2010, 02:30 PM   #3 (permalink)
Uhu, Not Gonna Happen!
gagan007's Avatar
nope not me...but I found a possible remedy in majorgeeks forum...please try and let us know...
forums.majorgeeks.com/showthread.php?t=219821
My personal blog - http://gagan.scholarguru.com
gagan007 is offline   Reply With Quote
Old 06-12-2010, 02:54 PM   #4 (permalink)
try using
Quick Heal, avira, kaspersky.
They might help.
Scan ur computer in safe mode with fully updated antivirus.
Also do you have any Linux installed.
abhijangda is offline   Reply With Quote
Old 06-12-2010, 03:09 PM   #5 (permalink)
Fullbring
Zangetsu's Avatar
@evewin89: the virus is still in ur system...so only removing frm pendrive wont help....
try bitdefender total security 2009 or 2010.....
try to format the pendrive from cmd....
Old 06-12-2010, 03:36 PM   #6 (permalink)
Freak Beta 1
Dark Core's Avatar
I would suggest you to go for Online Scanning,
Top 5 Online A/V Scanners : Top Online Scanners
Twitter : www.twitter.com/arunselvakumar :twisted:
Facebook : www.facebook.com/arunselvakumar :evil:
Dark Core is offline   Reply With Quote
Old 06-12-2010, 04:39 PM   #7 (permalink)
Joker
Posts: n/a
take back up of everything..
delete all partitions, parition, format and install XP form the scratch. virus again comes from ur other drives.
norton (everything) is crap...avira antivir is the best and only a good antivirus (no internet security suites) is more thn enough.
lastly..if u want to live a peaceful life..use Ubuntu linux and keep windows for gaming.
Old 06-12-2010, 04:45 PM   #8 (permalink)
Robin van Persie's Avatar
so true.
Robin van Persie is offline   Reply With Quote
Old 07-12-2010, 09:42 AM   #9 (permalink)
evewin89's Avatar
Originally Posted by Robin van Persie View Post
so true.
me to thinks the same......so i was thinking to switch to lixux but 1st i'll try to remove this virus by all the suggestion given by u all guys.
Old 07-12-2010, 04:15 PM   #10 (permalink)
1. get a good A/V in a pendrive from your friend. whose PC is clean.
2. Format C drive or windows partition & reinstall win.
3. as soon as PC back, insert pendrive, install A/V. & do a boot scan or total PC scan. DON'T EVEN THINK OF TOUCHING THE OTHER DRIVES until scan over.
4. delete/quantine/move-to-chest or do whatever with those maniacs.
5. now update your A/V & also if possible install a anti-spyware & do scan of the other drives with the A/S.
done. PC should be clean.
Old 09-12-2010, 06:53 PM   #11 (permalink)
evewin89's Avatar
thanks Sam.Shab for the info. 2day i again intalled xp after deleting "c" drive. an after intalling the os i installed avira antivir anti virus. then as soon as i began to install drivers for my computer from another drive the virus hit my computer. but avira antivir anti virus was able to detect which file got affected and it deleted those files. but i still know some where the virus is still there in my PC. i have lots of data on my other drive so i cannot format the whole computer. but i somehow think that formating the whole PC (including all the drives) is the only option left for me.
LinkBack to this Thread: http://www.thinkdigit.com/forum/software-q/134474-w32-ramnit-worm-please-help.html
W32 Ramnit Avira Personal - Linggars.com This thread Refback 04-05-2011 01:58 PM
w32/ramnit | BoardReader This thread Refback 30-12-2010 01:02 AM
Thread W32.Ramnit.a & Watermark.exe Removal | MajorGeeks Support Forums | BoardReader This thread Refback 14-12-2010 04:44 AM
- by chris
