Originally Posted by asingh
Did you try out what all is mentioned in the article by Abhidev.
yes i did dat....& also other tutorials available on net....
i think its a technical problem of bandwidth.....
in the peers tab i can c many Ips....& the download speed i m getting from them....& they r almost 100% status....but maximum number of IPs r idle not
sending any data to me...wats the reason.....?????
Is it possible to connect to all seeds in the swarm....
for e.g: 20(88) means 20 seeds r giving me seeds out of 88 in swarms
dat means 68seeds from swarm r not connected to me...so cant i connect 2 all 88seeds......????
