First of all go to folder option and select
#show hidden files and folders
#show system protected files and folders
Now go to c drive, there you will find a file by name "boot.ini"
Right click on the file>Properties>remove the real only attribute
Next open the file in notepad, it will look like this
[boot loader]
timeout=3
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOW S
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Windo ws XP pro" /noexecute=optin /fastdetect
Just delete the first two entries
remember only the first two, don't edit anything else, next save the file and make it read only by: right click>properties
reboot your system
