Old 21-11-2010, 12:03 AM   #1 (permalink)
rakz's Avatar
Default How to insert a code box in MS Word
How to insert a code box in MS Word ? like the one present here
Like This
I had seen a document with this type of box...pls help
rakz is offline   Reply With Quote
Old 21-11-2010, 01:53 AM   #2 (permalink)
Default Re: How to insert a code box in MS Word
Not very sure what you are looking for..but one simple way could be just insert a text box from 'Insert' Menu at a cursor position where you wish to display the code.
Then click and drag to draw the box.
Later you can insert a text into it, right click on the borderline of the box and select Edit text. If you wish to display a programming source code inside this box, use courier new font. The tabs in the source code will get properly indented in there with this font
patkim is offline   Reply With Quote
- by chris
