Old 17-11-2010, 04:38 PM   #1 (permalink)
ajayritik's Avatar
Default Need to edit a document. What is the best way to do it?
I have one document which needs to be edited (Hard Copy). What would be the best way to have it edited. Should I have it scanned and then take the PDF that comes out of it as source and then using some PDF editing software to edit the document. I think will have to go for some OCR Software.
Kindly help!
ajayritik is offline   Reply With Quote
Old 17-11-2010, 04:53 PM   #2 (permalink)
Default Re: Need to edit a document. What is the best way to do it?
Use a good OCR software like OmniPage.
Old 17-11-2010, 06:22 PM   #3 (permalink)
Fullbring
Zangetsu's Avatar
@ajayritik:yes use OCR for ur requirement....
Old 17-11-2010, 06:27 PM   #4 (permalink)
ajayritik's Avatar
I scanned the document into a TIFF format. Now I think I need to find a software or application which will allow me to edit TIFF file and then save it.
Old 17-11-2010, 06:29 PM   #5 (permalink)
Actually you now need a software which can perform OCR on that document in TIFF format and save it as a Word document.
Old 17-11-2010, 07:57 PM   #6 (permalink)
ajayritik's Avatar
Searching for an OCR software now to do the same.
Old 17-11-2010, 08:29 PM   #7 (permalink)
if you have full microsoft office there is one office tool microsoft office document imaging in that itself you can scan the document and run OCR on it, but the typed words should be clear, if you have less than 5 pages better type it fast if you have more than 5 pages use OCR and then edit the mistakes which OCR makes in recognizing certain phrases, words, numbers, symbols and aligning formats ,etc/.
rsk11584 is offline   Reply With Quote
Old 18-11-2010, 12:16 PM   #8 (permalink)
ajayritik's Avatar
The problem here is I don't have scanner at home I will have to scan it at office and then edit it at home. The scanner at office is giving me output option as only TIFF and JPEG. Not sure if I can edit this formats. I have currently saved it as TIFF.
Old 18-11-2010, 01:29 PM   #9 (permalink)
gkbhat.blogspot.com
If you have tiff files then tesseract is the best you can get.
tesseract-ocr - Project Hosting on Google Code
It was one of the top three when it was tested in 1995 and still is a very good one.
blogging at http://gkbhat.blogspot.com
gk2k is offline   Reply With Quote
Old 18-11-2010, 02:54 PM   #10 (permalink)
ajayritik's Avatar
Anybody aware of any online versions available which will let me edit TIFF Files.
Old 08-12-2010, 03:13 AM   #11 (permalink)
Nat
Check out Ricoh Innovations' free beta version of their OCR software. You can access it online at: Document Conversion | beta.rii.ricoh.com
Nat is offline   Reply With Quote
- by chris
