Old 15-10-2010, 07:50 AM   #1 (permalink)
Pravas's Avatar
Question How To Limit Speed On Beetel 450BX 1
Hi Guys, i am having 384KBps Internet connection shared between 3 users(2 Wired+1 Wireless). The other wired user usually downloads stuffs from torrent and as a result the websites takes too long to open.
So if anyone out there could help me limit speed through router, it would be very helpful.
!!!!*Little Knowledge Is Dangerous*!!!!!
Pravas is offline   Reply With Quote
Old 15-10-2010, 08:32 AM   #2 (permalink)
Who
Guess Who's Back
Who's Avatar
Default Re: How To Limit Speed On Beetel 450BX 1
you can use softwares like Antamedia Bandwidth Manager , cause they mange bandwidth kilobyte, rather than IP to IP or rules so it's easier to do it. it can also be done using modem itself provided it supports such features so i advised to stay bandwidth managers like i mention above.
Stay Hungry. Stay Foolish.
Who is offline   Reply With Quote
Old 15-10-2010, 09:10 AM   #3 (permalink)
Pravas's Avatar
Question Re: How To Limit Speed On Beetel 450BX 1
Thanks For the Quick Reply, i'll try this.
But i would still like to know if it could be done through router..Thanks
Old 15-10-2010, 10:38 AM   #4 (permalink)
Pravas's Avatar
@Who
I am not able to select "Network Interface 2" at initial setup either way
- by chris
