Old 06-10-2010, 06:26 PM   #1 (permalink)
~ Harsh ~
hdsk.23's Avatar
Question Strange 4GB RAM Problem....
Hello Everybody
I have recently installed the 2GB(1X2) and now current total RAM is 4GB.
OS is Windows XP 32-bit
My motherboard specs are:
CPU AMD Socket 939 Athlon64/Athlon64 FX/Athlon64 X2/ Processors
AMD Cool 'n' Quiet™ Technology
Chipset NVIDIA GeForce 6100 + nForce 410
System Bus 2000/1600 MT/s
Memory 4 x184-pin DIMM, Max. 4 GB, DDR 400/333/266 ECC,Non-ECC,Un-buffered Memory
Dual Channel memory architecture
VGA Integrated GeForce 6 GPU
Expansion Slots 1 x PCIe x16
1 x PCIe x1
2 x PCI
Storage 2 xUltraDMA 133/100/66/33
2 xSATA 3 Gb/s ports Support RAID 0,1,
NVIDIA MediaShield storage management technology
LAN Integrated 100/10 Mb MAC with Realtek RTL8201CL external PHY
Audio High Definition Audio, ADI AD1986A 5 -Channel CODEC
S/PDIF out on back I/O port
Support Jack-Sensing
USB 8 USB 2.0 ports
Special Features ASUS MyLogo 2
ASUS EZ Flash
ASUS CrashFree BIOS 2
ASUS C.P.R.(CPU Parameter Recall)
ASUS Q-Fan
SFS (Stepless Frequency Selection)
Back Panel I/O Ports 1 x Parallel
1 x VGA
1 x PS/2 Keyboard
1 x PS/2 Mouse
1 x LAN(RJ45) port
4 x USB 2.0/1.1
5 -Channel Audio I/O
Internal I/O Connectors 2 x USB connectors supports additional 4 USB 2.0 ports
1 x CPU Fan connector
1 x Chassis Fan connector
1 x S/PDIF Out connector
1 x4-pin ATX 12V Power connector
24 -pin ATX Power connector
Front panel audio connector
COM connector
Chassis Intrusion connector
CD/AUX audio in
Support Disc Drivers
ASUS PC Probe II
Anti-virus software (OEM version)
ASUS LiveUpdate Utility
AMD Cool 'n' Quiet Utility
Accessories User's manual
x UltraDMA 133/100/66 cables
x Floppy disk drive cables
x SATA cables
SATA power cables
I/O Shield
BIOS 4 Mb Flash ROM
DMI 2.0
PnP
WfM 2.0
SM BIOS 2.3
ACPI 2.0
Form Factor uATX Form Factor
9.6 inch x 9.6 inch ( 24.5 cm x 24.5 cm )
The problem i am facing is windows xp shows only 2.62GB of RAM available. I have allocated 128MB to GPU on-board graphics which is max. i can give. I have also installed the Windows 7 x64 bit but got same problem 4GB(2.63 usable). I know that 32-bit OS can support upto 3.5Gb ram but here it is using only 2.62 What is this funda please help me....
hdsk.23 is offline   Reply With Quote
Old 06-10-2010, 07:15 PM   #2 (permalink)
The Assassin
Cybertonic's Avatar
Default Re: Strange 4GB RAM Problem....
where did you get these specs? please post your system specs using a software like flitskikker info tool or cpu-z.
Nothing is true. Everything is permitted.
Steam : $/@$]-[ DK
http://steamcommunity.com/profiles/76561198047340352
Cybertonic is offline   Reply With Quote
Old 06-10-2010, 07:21 PM   #3 (permalink)
~ Harsh ~
hdsk.23's Avatar
these specs are taken from the Asus official site..
motherboard name is A8N-VM
Old 06-10-2010, 07:23 PM   #4 (permalink)
~ Harsh ~
hdsk.23's Avatar
and the CPU-z info is here..
CPU-Z version 1.40.5
Processors Map
Number of processors 1
Number of threads 1
Processor 0
-- Core 0
-- Thread 0
Processors Information
Processor 1 (ID = 0)
Number of cores 1
Number of threads 1 (max 1)
Name AMD Athlon 64 3000+
Codename Venice
Specification AMD Athlon(tm) 64 Processor 3000+
Package Socket 939
CPUID F.F.2
Extended CPUID F.2F
Brand ID 4
Core Stepping DH-E6
Technology 90 nm
Core Speed 1808.3 MHz (9.0 x 200.9 MHz)
HT Link speed 1004.6 MHz
Stock frequency 1800 MHz
Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64
L1 Data cache 64 KBytes, 2-way set associative, 64-byte line size
L1 Instruction cache 64 KBytes, 2-way set associative, 64-byte line size
L2 cache 512 KBytes, 16-way set associative, 64-byte line size
FID/VID Control yes
max FID 9.0x
VID range 1.100V - 1.450V
K8 Thermal sensor yes
K8 Revision ID 4.2
Attached device PCI device at bus 0, device 24, function 0
Attached device PCI device at bus 0, device 24, function 1
Attached device PCI device at bus 0, device 24, function 2
Attached device PCI device at bus 0, device 24, function 3
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 02002001h
Max CPUID level 00000001h
Max CPUID ext. level 80000018h
Function eax ebx ecx edx
0x00000000 0x00000001 0x68747541 0x444D4163 0x69746E65
0x00000001 0x00020FF2 0x00000800 0x00000001 0x078BFBFF
0x80000000 0x80000018 0x68747541 0x444D4163 0x69746E65
0x80000001 0x00020FF2 0x00000108 0x00000001 0xE3D3FBFF
0x80000002 0x20444D41 0x6C687441 0x74286E6F 0x3620296D
0x80000003 0x72502034 0x7365636F 0x20726F73 0x30303033
0x80000004 0x0000002B 0x00000000 0x00000000 0x00000000
0x80000005 0xFF08FF08 0xFF20FF20 0x40020140 0x40020140
0x80000006 0x00000000 0x42004200 0x02008140 0x00000000
0x80000007 0x00000000 0x00000000 0x00000000 0x0000003F
0x80000008 0x00003028 0x00000000 0x00000000 0x00000000
0x80000009 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000A 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000B 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000C 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000D 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000E 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000F 0x00000000 0x00000000 0x00000000 0x00000000
0x80000010 0x00000000 0x00000000 0x00000000 0x00000000
0x80000011 0x00000000 0x00000000 0x00000000 0x00000000
0x80000012 0x00000000 0x00000000 0x00000000 0x00000000
0x80000013 0x00000000 0x00000000 0x00000000 0x00000000
0x80000014 0x00000000 0x00000000 0x00000000 0x00000000
0x80000015 0x00000000 0x00000000 0x00000000 0x00000000
0x80000016 0x00000000 0x00000000 0x00000000 0x00000000
0x80000017 0x00000000 0x00000000 0x00000000 0x00000000
0x80000018 0x00000000 0x00000000 0x00000000 0x00000000
MSR 0x0000001B edx = 0x00000000 eax = 0xFEE00900
MSR 0xC001001E edx = 0x00000000 eax = 0x00000042
MSR 0xC0010015 edx = 0x00000000 eax = 0x0A000000
MSR 0xC0010042 edx = 0x12040606 eax = 0x040A0A0A
MSR 0xC0010041 edx = 0x00000001 eax = 0x0000060A
Chipset
Northbridge NVIDIA GeForce 6100 rev. A2
Southbridge NVIDIA nForce 410/430 MCP rev. A2
Memory Type DDR
Memory Size 4096 MBytes
Memory Frequency 164.4 MHz (CPU/11)
CAS# 2.5
RAS# to CAS# 3
RAS# Precharge 3
Cycle Time (tRAS) 7
Bank Cycle Time (tRC) 10
DRAM Idle Timer 16
Command Rate 2T
Memory SPD
DIMM #1
General
Memory type DDR
Manufacturer (ID) (7F7F7F7F7FDC0000)
Size 1024 MBytes
Max bandwidth PC3200 (200 MHz)
Part number HEXON
Attributes
Number of banks 2
Data width 64 bits
Correction None
Registered no
Buffered no
EPP no
Timings table
Frequency (MHz) 133 166 200
CAS# 2.0 2.5 3.0
RAS# to CAS# delay 3 3 4
RAS# Precharge 3 3 4
TRAS 6 7 8
DIMM #2
General
Memory type DDR
Size 1024 MBytes
Part number HEXON
Attributes
Number of banks 2
Data width 64 bits
Correction None
Registered no
Buffered no
EPP no
Timings table
CAS# 2.0 2.5 3.0
TRAS 6 7 8
DIMM #3
General
Memory type DDR
Manufacturer (ID) Hyundai Electronics (AD44594E45540000)
Size 1024 MBytes
Part number
Attributes
Number of banks 2
Data width 64 bits
Correction None
Registered no
Buffered no
EPP no
Timings table
Frequency (MHz) 166 200
CAS# 2.5 3.0
RAS# Precharge 3 3
TRAS 7 8
DIMM #4
General
Memory type DDR
Size 1024 MBytes
Part number
Attributes
Number of banks 2
Data width 64 bits
Correction None
Registered no
Buffered no
EPP no
Timings table
CAS# 2.5 3.0
RAS# Precharge 3 3
TRAS 7 8
Dump Module #1
0 1 2 3 4 5 6 7 8 9 A B C D E F
00 80 08 07 0D 0B 02 40 00 04 50 70 00 82 08 00 01
10 0E 04 1C 01 02 20 C0 60 70 75 75 48 28 48 28 80
20 60 60 40 40 00 00 00 00 00 3C 46 20 28 50 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 10 CD
40 7F 7F 7F 7F 7F DC 00 00 00 48 45 58 4F 4E 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 00 00 00 00 00 00 00 00 18 04 07 02 10 00 00 00
70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Dump Module #2
60 00 00 00 00 00 00 00 00 18 04 07 02 13 00 00 00
Dump Module #3
00 80 08 07 0D 0B 02 40 00 04 50 65 00 82 08 00 01
10 0E 04 18 01 02 20 00 60 70 00 00 3C 28 3C 28 80
20 60 60 40 40 00 00 00 00 00 37 46 20 28 50 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 10 F7
40 AD 44 59 4E 45 54 00 00 00 00 00 00 00 00 00 00
60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Dump Module #4
Monitoring
Sensor Chip Winbond W83627EHF
PCI Device List
RAM Memory Controller
bus 0 (0x00), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x02F1
Revision ID 0xA2
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1043
Subsystem ID 0x81BF
Int. Line 0xFF
Int. Pin 0x00
Capabilities
HyperTransport Capability
Offset 44h
Revision 1.03
Interface type Slave/Primary
Link 0 width (in/out) 16 bits/16 bits
Link 0 frequency 1000MHz
Link 1 width (in/out) 8 bits/8 bits
Link 1 frequency 400MHz
Offset E0h
Interface type MSI mapping
Dump
00 DE 10 F1 02 06 01 B0 00 A2 00 00 05 00 00 80 00
10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 43 10 BF 81
30 00 00 00 00 44 00 00 00 00 00 00 00 FF 00 00 00
40 43 10 BF 81 08 E0 E0 01 22 00 11 11 22 30 11 00
50 23 06 7F 80 03 02 7F 80 00 00 03 00 00 00 00 00
60 00 00 00 00 00 00 00 00 00 00 00 00 06 36 05 00
70 44 44 44 00 D0 09 00 00 11 00 00 00 11 11 88 00
80 23 99 88 00 1F 00 64 0C 03 00 00 00 7F 00 00 00
90 70 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00
A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 01 01 01 01 00 00 00 00 00 00 00 00
C0 00 00 00 00 00 00 00 00 00 00 00 00 61 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 08 00 00 A8 00 00 E0 FE 00 00 00 00 00 00 00 10
F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
bus 0 (0x00), device 0 (0x00), function 1 (0x01)
Common header
Vendor ID 0x10DE
Model ID 0x02FA
Revision ID 0xA2
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1043
Subsystem ID 0x81BF
Int. Line 0x00
Int. Pin 0x00
Dump
00 DE 10 FA 02 00 01 20 00 A2 00 00 05 00 00 80 00
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 00 00 10 00 21 21 14 00 11 11 00 00 03 00 00 00
60 21 88 13 02 DE 8F E1 1F 08 72 4E 10 02 3F 00 20
70 10 32 54 0A 10 00 00 00 A0 00 00 00 02 00 01 01
80 00 35 0C 00 00 00 00 00 00 00 50 3F 90 3F 00 00
90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 01 00 00 00 80 F9 FD 00
E0 00 00 B9 FE 00 00 00 00 00 FC FF FF 00 00 00 00
F0 00 00 00 00 C7 02 32 00 00 00 00 00 00 00 00 00
bus 0 (0x00), device 0 (0x00), function 2 (0x02)
Common header
Vendor ID 0x10DE
Model ID 0x02FE
Revision ID 0xA2
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1043
Subsystem ID 0x81BF
Int. Line 0x00
Int. Pin 0x00
Dump
00 DE 10 FE 02 00 00 20 00 A2 00 00 05 00 00 80 00
40 43 10 BF 81 1F 20 1C A0 1F 20 C0 21 00 00 00 00
50 51 30 54 C9 01 00 00 00 50 30 53 C9 02 1F 1C 80
60 02 1F 1C 00 00 00 00 00 02 10 1C A0 02 0C 1C 90
70 02 10 1C 90 02 14 1C 90 02 0C 1C 80 02 10 1C 80
80 02 14 1C 80 02 18 1C 80 02 1C 1C 80 01 10 1C 80
90 02 14 1C 80 11 00 11 00 32 01 00 00 00 00 00 00
A0 C2 00 40 01 10 00 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 00 00 00 00 00 00 00 00 41 23 05 08
C0 FD FF FF FF FF FF FF FF 00 00 00 00 00 00 00 00
E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
bus 0 (0x00), device 0 (0x00), function 3 (0x03)
Common header
Vendor ID 0x10DE
Model ID 0x02F8
Revision ID 0xA2
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1043
Subsystem ID 0x81BF
Int. Line 0xFF
Int. Pin 0x00
Dump
00 DE 10 F8 02 00 01 A0 00 A2 00 00 05 00 00 80 00
30 00 00 00 00 00 00 00 00 00 00 00 00 FF 00 00 00
40 43 10 BF 81 00 00 00 00 02 10 1C 90 02 10 1C A0
50 02 0C 1C 90 02 10 1C 90 02 14 1C 90 02 0C 1C 80
60 02 10 1C 80 02 14 1C 80 02 18 1C 80 02 1C 1C 80
70 01 10 1C 80 1F 20 C0 81 00 00 00 00 00 00 00 00
80 00 00 00 00 97 00 FF AC 02 1F 1C 80 70 20 00 00
90 89 DA 01 09 00 00 00 00 11 00 10 00 00 00 00 00
B0 08 00 00 00 72 19 00 00 10 00 02 00 00 28 00 28
C0 80 00 00 00 00 00 00 00 01 01 00 05 00 00 00 00
D0 00 00 F0 03 00 04 00 00 00 00 00 00 00 00 00 00
F0 60 EA 10 10 18 00 00 20 00 00 00 00 00 00 00 00
bus 0 (0x00), device 0 (0x00), function 4 (0x04)
Common header
Vendor ID 0x10DE
Model ID 0x02F9
Revision ID 0xA2
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x1043
Subsystem ID 0x81BF
Int. Line 0xFF
Int. Pin 0x00
Dump
00 DE 10 F9 02 06 01 A0 00 A2 00 00 05 00 00 00 00
40 EF DD 7B 2F F7 DE 7B 2F F7 DE 7B 2F F7 02 00 00
60 00 00 00 00 00 00 00 00 03 00 00 00 00 00 00 00
70 0A 00 00 00 03 00 00 00 25 00 00 00 00 00 00 00
80 00 00 00 00 00 00 00 00 05 00 00 00 04 00 00 00
90 03 04 00 00 01 00 00 00 00 00 00 00 00 00 00 00
B0 FF 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00
bus 0 (0x00), device 0 (0x00), function 5 (0x05)
Common header
Vendor ID 0x10DE
Model ID 0x02FF
Revision ID 0xA2
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1043
Subsystem ID 0x81BF
Int. Line 0xFF
Int. Pin 0x00
Capabilities
PCI Capability class 0x0
Offset 44h
Offset FCh
Dump
00 DE 10 FF 02 06 01 B0 00 A2 00 00 05 00 00 80 00
40 17 00 00 00 00 FE FE 00 00 FE FE 00 00 FE FE 00
50 00 FE FE 00 00 FE FE 00 00 FE FE 00 00 00 00 00
80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
bus 0 (0x00), device 0 (0x00), function 6 (0x06)
Common header
Vendor ID 0x10DE
Model ID 0x027F
Revision ID 0xA2
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1043
Subsystem ID 0x81BF
Int. Line 0x00
Int. Pin 0x00
Dump
00 DE 10 7F 02 02 01 20 00 A2 00 00 05 00 00 80 00
40 08 00 00 00 00 00 00 00 00 80 BB FE 00 00 00 00
bus 0 (0x00), device 0 (0x00), function 7 (0x07)
Common header
Vendor ID 0x10DE
Model ID 0x027E
Revision ID 0xA2
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1043
Subsystem ID 0x81BF
Int. Line 0x00
Int. Pin 0x00
Dump
00 DE 10 7E 02 00 00 20 00 A2 00 00 05 00 00 80 00
40 43 10 BF 81 11 00 00 00 75 07 00 00 11 00 00 00
50 74 06 00 00 40 00 60 00 40 60 00 00 00 00 00 00
80 00 00 00 00 00 00 00 00 00 00 00 04 00 00 00 04
A0 00 00 00 00 00 00 00 00 00 00 00 04 00 00 00 04
B0 FF FF 03 00 10 11 00 00 AC 10 20 00 30 00 00 00
PCI to PCI Bridge
bus 0 (0x00), device 2 (0x02), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x02FC
Revision ID 0xA1
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x01
Int. Line 0x00
Int. Pin 0x00
Capabilities
Subsystem Vendor Capability
Offset 40h
Subsystem ID 0x0000
Sub. Vendor ID 0x10DE
Power Management Capability
Offset 48h
Version 1.1
Message Signalled Interrupts Capability
Offset 50h
Offset 60h
PCI Express Capability
Offset 80h
Device type Root Port of PCI-E Root Complex
Port 2
Version 1.0
Physical slot #0
Presence detect no
Link width 1x (max 1x)
Extended capabilities
Virtual Channel
Offset 100h
Dump
00 DE 10 FC 02 07 00 10 00 A1 00 04 06 10 00 01 00
10 00 00 00 00 00 00 00 00 00 01 01 00 F1 01 00 00
20 F0 FF 00 00 F1 FF 01 00 00 00 00 00 00 00 00 00
30 00 00 00 00 40 00 00 00 00 00 00 00 00 00 02 00
40 0D 48 00 00 DE 10 00 00 01 50 02 F8 00 00 00 00
50 05 60 82 00 00 00 00 00 00 00 00 00 00 00 00 00
60 08 80 00 A8 00 00 E0 FE 00 00 00 00 00 00 00 00
80 10 00 41 01 C0 04 00 00 10 28 00 00 11 34 11 02
90 00 00 11 10 00 00 00 00 C0 01 00 00 00 00 00 00
PCI to PCI Bridge
bus 0 (0x00), device 3 (0x03), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x02FD
Revision ID 0xA1
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x02
Int. Line 0x00
Int. Pin 0x00
Capabilities
Offset 40h
Subsystem ID 0x0000
Offset 48h
Version 1.1
Offset 50h
Offset 60h
Offset 80h
Port 1
Version 1.0
Physical slot #0
Presence detect no
Virtual Channel
Offset 100h
Dump
00 DE 10 FD 02 07 00 10 00 A1 00 04 06 10 00 01 00
10 00 00 00 00 00 00 00 00 00 02 02 00 F1 01 00 00
80 10 00 41 01 C0 04 00 00 10 28 00 00 11 34 11 01
PCI to PCI Bridge
bus 0 (0x00), device 4 (0x04), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x02FB
Revision ID 0xA1
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x03
Int. Line 0x00
Int. Pin 0x00
Capabilities
Offset 40h
Subsystem ID 0x0000
Offset 48h
Version 1.1
Offset 50h
Offset 60h
Offset 80h
Port 0
Version 1.0
Physical slot #0
Presence detect no
Link width 16x (max 16x)
Virtual Channel
Offset 100h
Dump
00 DE 10 FB 02 07 00 10 00 A1 00 04 06 10 00 01 00
10 00 00 00 00 00 00 00 00 00 03 03 00 F1 01 00 00
80 10 00 41 01 C0 04 00 00 10 28 00 00 01 35 11 00
90 00 00 01 11 00 00 00 00 C0 01 00 00 00 00 00 00
VGA Controller
bus 0 (0x00), device 5 (0x05), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x0242
Revision ID 0xA2
PI 0x00
SubClass 0x00
BaseClass 0x03
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xFD000000
Address 1 (memory) 0xD0000000
Address 3 (memory) 0xFC000000
Subvendor ID 0x1043
Subsystem ID 0x81BF
Int. Line 0x12
Int. Pin 0x01
Capabilities
Offset 48h
Version 1.1
Offset 50h
Dump
00 DE 10 42 02 07 00 B0 00 A2 00 00 03 00 00 00 00
10 00 00 00 FD 0C 00 00 D0 00 00 00 00 04 00 00 FC
30 00 00 00 00 48 00 00 00 00 00 00 00 12 01 00 00
40 43 10 BF 81 00 00 00 00 01 50 02 00 00 00 00 00
50 05 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00
60 01 00 00 00 04 00 00 00 00 00 00 00 01 00 00 00
70 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
80 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
90 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
A0 00 00 50 01 00 00 00 08 00 00 00 00 FF FF FF FF
B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
bus 0 (0x00), device 9 (0x09), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x0270
Revision ID 0xA2
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x1043
Subsystem ID 0x81C0
Int. Line 0x00
Int. Pin 0x00
Capabilities
Offset 44h
Revision 1.03
Link 0 width (in/out) 8 bits/8 bits
Link 0 frequency 400MHz
Link 1 frequency 200MHz
Offset E0h
Dump
00 DE 10 70 02 06 00 B0 00 A2 00 00 05 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 43 10 C0 81
30 00 00 00 00 44 00 00 00 00 00 00 00 00 00 00 00
40 43 10 C0 81 08 E0 E9 01 22 30 00 00 D0 00 00 00
50 23 02 7F 80 03 00 00 00 00 00 03 00 00 00 00 00
60 00 00 00 00 00 00 00 00 00 00 00 00 06 15 05 00
70 44 44 44 00 D0 09 00 00 11 00 00 00 11 11 55 00
80 23 55 55 00 FA 00 64 0C 03 00 00 00 7F 00 00 00
C0 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00 00
E0 08 00 01 A8 00 00 E0 FE 00 00 00 00 00 00 00 00
PCI to ISA Bridge
bus 0 (0x00), device 10 (0x0A), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x0261
Revision ID 0xA2
PI 0x00
SubClass 0x01
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1043
Subsystem ID 0x81C0
Int. Line 0xFF
Int. Pin 0x00
Dump
00 DE 10 61 02 0F 00 A0 00 A2 00 01 06 00 00 80 00
40 43 10 C0 81 00 00 00 00 FA 3E FF 00 FA 3E FF 00
50 FA 3E FF 00 00 5A 62 02 00 00 00 01 00 00 FE A7
60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F9 FF
70 10 00 FF FF C1 00 00 00 00 00 45 19 60 00 00 06
80 09 D0 00 D0 01 80 00 00 F0 00 00 01 00 00 00 00
90 00 00 00 00 00 00 00 00 21 47 65 B7 EF CD 00 00
A0 FE 00 10 17 00 00 00 00 95 02 96 02 00 00 00 00
F0 00 00 00 00 00 00 00 00 10 00 00 00 00 00 00 00
SMBus Controller
bus 0 (0x00), device 10 (0x0A), function 1 (0x01)
Common header
Vendor ID 0x10DE
Model ID 0x0264
Revision ID 0xA2
PI 0x00
SubClass 0x05
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 4 (port) 0x00000600
Address 5 (port) 0x00000700
Subvendor ID 0x1043
Subsystem ID 0x81C0
Int. Line 0x05
Int. Pin 0x01
Capabilities
Offset 44h
Version 1.1
Dump
00 DE 10 64 02 01 00 B0 00 A2 00 05 0C 00 00 80 00
20 01 06 00 00 01 07 00 00 00 00 00 00 43 10 C0 81
30 00 00 00 00 44 00 00 00 00 00 00 00 05 01 00 00
40 43 10 C0 81 01 00 02 C0 00 00 00 00 00 00 00 00
60 01 05 00 00 01 08 00 00 01 09 00 00 00 00 00 00
70 01 00 00 00 00 00 B8 FE 00 00 FE FE 01 20 00 00
C0 D4 30 80 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 10 10 04 00 00 A0 90 00 80 34 04 00 41 44 44 11
F0 5A FF 5F BF 00 00 00 C0 10 00 00 00 00 00 00 00
USB Controller (OHCI)
bus 0 (0x00), device 11 (0x0B), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x026D
Revision ID 0xA2
PI 0x10
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 0 (memory) 0xFEBDE000
Subvendor ID 0x1043
Subsystem ID 0x81C0
Int. Line 0x17
Int. Pin 0x01
Capabilities
Offset 44h
Version 1.1
Dump
00 DE 10 6D 02 07 00 B0 00 A2 10 03 0C 00 00 80 00
10 00 E0 BD FE 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 44 00 00 00 00 00 00 00 17 01 03 01
40 43 10 C0 81 01 00 02 FE 00 00 00 00 00 00 00 00
50 02 00 00 00 1D 47 40 00 10 00 00 00 00 00 00 00
USB 2.0 Controller (EHCI)
bus 0 (0x00), device 11 (0x0B), function 1 (0x01)
Common header
Vendor ID 0x10DE
Model ID 0x026E
Revision ID 0xA2
PI 0x20
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 0 (memory) 0xFEBDFC00
Subvendor ID 0x1043
Subsystem ID 0x81C0
Int. Line 0x15
Int. Pin 0x02
Capabilities
Debug Port Capability
Offset 44h
Offset 80h
Version 1.1
Dump
00 DE 10 6E 02 06 00 B0 00 A2 20 03 0C 00 00 80 00
10 00 FC BD FE 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 44 00 00 00 00 00 00 00 15 02 03 01
40 43 10 C0 81 0A 80 98 20 00 00 00 00 00 00 00 00
60 20 20 01 00 00 60 18 85 03 3C 0A 01 00 00 00 00
70 00 00 08 05 00 10 20 80 89 3D B6 22 77 25 44 00
80 01 00 02 FE 00 00 00 00 00 00 00 00 15 16 00 00
A0 01 00 00 00 00 20 00 C0 00 00 00 00 00 00 00 00
B0 33 00 11 22 00 00 00 00 FF 00 00 00 00 00 00 00
C0 10 10 2D 0D 00 00 00 00 00 00 00 00 00 00 00 00
IDE Controller
bus 0 (0x00), device 13 (0x0D), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x0265
Revision ID 0xA1
PI 0x8A
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 4 (port) 0x0000FFA0
Subvendor ID 0x1043
Subsystem ID 0x81C0
Int. Line 0x00
Int. Pin 0x00
Capabilities
Offset 44h
Version 1.1
Dump
00 DE 10 65 02 05 00 B0 00 A1 8A 01 01 00 00 00 00
20 A1 FF 00 00 00 00 00 00 00 00 00 00 43 10 C0 81
30 00 00 00 00 44 00 00 00 00 00 00 00 00 00 03 01
40 43 10 C0 81 01 00 02 00 00 00 00 00 00 00 00 00
50 03 F0 01 00 00 00 00 00 A8 A8 11 20 7F 00 FF 20
60 00 00 00 C5 00 00 00 00 00 00 00 00 00 00 00 00
80 00 00 00 00 70 C1 BA 82 00 00 C0 1F 00 00 00 00
IDE Controller
bus 0 (0x00), device 14 (0x0E), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x0266
Revision ID 0xA1
PI 0x85
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (port) 0x0000E800
Address 1 (port) 0x0000E480
Address 2 (port) 0x0000E400
Address 3 (port) 0x0000E080
Address 4 (port) 0x0000E000
Address 5 (memory) 0xFEBDD000
Subvendor ID 0x1043
Subsystem ID 0x81C0
Int. Line 0x15
Int. Pin 0x01
Capabilities
Offset 44h
Version 1.1
Offset B0h
Offset CCh
Dump
00 DE 10 66 02 07 00 B0 00 A1 85 01 01 00 00 00 00
10 01 E8 00 00 81 E4 00 00 01 E4 00 00 81 E0 00 00
20 01 E0 00 00 00 D0 BD FE 00 00 00 00 43 10 C0 81
30 00 00 00 00 44 00 00 00 00 00 00 00 15 01 03 01
40 43 10 C0 81 01 B0 02 00 00 00 00 00 00 00 00 00
50 07 00 00 00 00 00 00 00 00 20 00 20 44 20 00 20
60 00 C7 00 C7 51 0C 00 00 00 0F 06 42 00 00 00 00
70 2C 78 C4 40 01 10 00 00 01 10 00 00 20 00 20 00
80 00 00 00 C0 00 80 D7 0D 00 00 40 80 00 80 F4 09
90 00 00 08 B0 00 00 00 00 06 00 06 10 00 00 01 01
A0 14 10 00 30 00 00 00 00 00 00 00 00 33 33 00 02
B0 05 CC 84 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 00 00 00 00 00 00 00 0A 00 0A 00 08 00 02 A8
D0 0A 00 02 6C 42 00 00 00 00 00 00 00 0F 00 00 E0
E0 0A 00 02 6C 42 00 00 00 00 00 00 00 0F 00 A0 E7
F0 00 00 00 00 00 00 00 00 00 00 0C 00 00 00 00 00
PCI to PCI Bridge
bus 0 (0x00), device 16 (0x10), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x026F
Revision ID 0xA2
PI 0x01
SubClass 0x04
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x81
PCI header
Primary bus 0x00
Secondary bus 0x04
Int. Line 0x00
Int. Pin 0x00
Capabilities
Offset B8h
Subsystem ID 0x0000
Sub. Vendor ID 0x0000
Offset 8Ch
Dump
00 DE 10 6F 02 07 00 B0 00 A2 01 04 06 00 00 81 00
10 00 00 00 00 00 00 00 00 00 04 04 40 F0 00 80 02
20 F0 FF 00 00 F0 FF 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 B8 00 00 00 00 00 00 00 00 00 02 02
40 00 00 03 00 01 00 02 00 05 00 00 00 00 00 44 00
50 00 00 FE A7 00 00 00 00 FF 1F FF 1F 00 00 00 00
80 00 00 00 00 00 00 00 00 00 00 00 00 08 00 00 A8
90 00 00 E0 FE 00 00 00 00 00 00 00 00 00 00 00 00
A0 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 FF FF 00 00 0D 8C 00 00 00 00 00 00
C0 00 00 00 00 03 00 00 00 00 00 00 00 00 00 00 00
Multimedia device
bus 0 (0x00), device 16 (0x10), function 1 (0x01)
Common header
Vendor ID 0x10DE
Model ID 0x026C
Revision ID 0xA2
PI 0x00
SubClass 0x03
BaseClass 0x04
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 0 (memory) 0xFEBD8000
Subvendor ID 0x10DE
Subsystem ID 0xCB84
Int. Line 0x14
Int. Pin 0x02
Capabilities
Offset 44h
Version 1.1
Offset 50h
Offset 6Ch
Dump
00 DE 10 6C 02 06 00 B0 00 A2 00 03 04 00 00 80 00
10 00 80 BD FE 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 DE 10 84 CB
30 00 00 00 00 44 00 00 00 00 00 00 00 14 02 02 05
40 DE 10 84 CB 01 50 02 C0 00 00 00 00 01 01 0F 00
50 05 6C 80 01 00 00 00 00 00 00 00 00 00 00 00 00
60 00 00 00 00 00 00 00 00 0F 00 00 00 08 00 02 A8
F0 00 00 00 00 00 00 00 46 00 29 00 00 00 00 00 00
Host Bridge
bus 0 (0x00), device 24 (0x18), function 0 (0x00)
Common header
Vendor ID 0x1022
Model ID 0x1100
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
Capabilities
Offset 80h
Revision 1.02
Interface type Host/Secondary
Device number 0
Dump
00 22 10 00 11 00 00 10 00 00 00 00 06 00 00 80 00
20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00
40 01 01 01 00 01 01 01 00 01 01 01 00 01 01 01 00
50 01 01 01 00 01 01 01 00 01 01 01 00 01 01 01 00
60 00 00 00 00 E4 00 00 00 0F CC 0E 0F 3C 00 00 00
80 08 00 01 21 20 00 11 11 22 06 75 80 02 00 00 00
90 69 01 61 01 00 00 FF 00 07 00 00 00 00 00 00 00
Host Bridge
bus 0 (0x00), device 24 (0x18), function 1 (0x01)
Common header
Vendor ID 0x1022
Model ID 0x1101
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
Dump
00 22 10 01 11 00 00 00 00 00 00 00 06 00 00 80 00
40 03 00 00 00 00 00 FF 00 00 00 00 00 01 00 00 00
50 00 00 00 00 02 00 00 00 00 00 00 00 03 00 00 00
60 00 00 00 00 04 00 00 00 00 00 00 00 05 00 00 00
70 00 00 00 00 06 00 00 00 00 00 00 00 07 00 00 00
80 03 00 E0 00 80 FF EF 00 00 00 00 00 00 00 00 00
B0 03 0A 00 00 00 0B 00 00 03 00 B0 00 00 0B FE 00
C0 13 10 00 00 00 F0 FF 00 00 00 00 00 00 00 00 00
E0 03 00 00 FF 00 00 00 00 00 00 00 00 00 00 00 00
Host Bridge
bus 0 (0x00), device 24 (0x18), function 2 (0x02)
Common header
Vendor ID 0x1022
Model ID 0x1102
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
Dump
00 22 10 02 11 00 00 00 00 00 00 00 06 00 00 80 00
40 01 00 00 00 01 20 00 00 01 40 00 00 01 60 00 00
60 00 9E E0 0F 00 9E E0 0F 00 9E E0 0F 00 9E E0 0F
80 77 00 00 00 00 00 00 00 35 33 72 13 30 0A 00 00
90 80 CC 05 3E 07 88 5B 3E 00 00 00 00 0D 02 00 00
B0 1C 82 4C 6B 21 00 00 00 7F FF 80 20 60 6C 28 07
C0 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 A5 04 27 02 80 35 35 A8 60 C5 6E 58 61 94 98 E3
E0 85 A0 E0 57 84 15 0A 15 48 63 2C 7D 00 01 BA 18
Host Bridge
bus 0 (0x00), device 24 (0x18), function 3 (0x03)
Common header
Vendor ID 0x1022
Model ID 0x1103
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
Dump
00 22 10 03 11 00 00 00 00 00 00 00 06 00 00 80 00
40 FF 3B 00 00 40 00 40 00 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 80 ED 39 E9
60 65 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00
70 11 01 02 51 22 30 00 50 00 1B 00 08 1F 22 00 00
80 00 00 07 23 13 21 13 21 00 00 00 00 00 00 00 00
90 00 00 00 00 C6 00 00 00 00 70 80 B0 00 00 00 00
B0 00 00 00 00 00 00 00 00 3F 00 00 00 00 00 00 00
D0 00 00 00 00 01 A7 0D 00 00 00 40 00 00 00 00 00
E0 00 00 00 00 20 01 61 04 19 05 00 00 00 00 00 00
Ethernet Controller
bus 4 (0x04), device 9 (0x09), function 0 (0x00)
Common header
Vendor ID 0x10EC
Model ID 0x8139
Revision ID 0x10
PI 0x00
SubClass 0x00
BaseClass 0x02
Cache Line 0x00
Latency 0x40
Header 0x00
PCI header
Address 0 (port) 0x0000D800
Address 1 (memory) 0xFAAFFC00
Subvendor ID 0x10EC
Subsystem ID 0x8139
Int. Line 0x12
Int. Pin 0x01
Capabilities
Offset 50h
Version 1.1
Dump
00 EC 10 39 81 07 01 90 02 10 00 00 02 00 40 00 00
10 01 D8 00 00 00 FC AF FA 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 EC 10 39 81
30 00 00 AC FA 50 00 00 00 00 00 00 00 12 01 20 40
50 01 00 02 76 00 00 00 00 00 00 00 00 00 00 00 00
DMI
DMI BIOS
vendor American Megatrends Inc.
version 0902
date 03/15/2006
DMI System Information
manufacturer System manufacturer
product System Product Name
version System Version
serial System Serial Number
UUID D831B285-74FED511-8A8014D7-885DDAD8
DMI Baseboard
vendor ASUSTeK Computer INC.
model A8N-VM
revision Rev 1.xx
serial MB-1234567890
DMI System Enclosure
manufacturer Chassis Manufacture
chassis type Desktop
chassis serial Chassis Serial Number
DMI Processor
manufacturer AMD
model AMD Athlon(tm) 64 Processor 3000+
clock speed 1800.0MHz
FSB speed 200.0MHz
multiplier 9.0x
DMI Memory Controller
correction 64-bit ECC
Max module size 4096MBytes
DMI Memory Module
designation DIMM0
size 1024MBytes (double bank)
DMI Memory Module
designation DIMM1
DMI Memory Module
designation DIMM2
DMI Memory Module
designation DIMM3
DMI Port Connector
designation PS2Mouse (external)
port type Mouse Port
connector PS/2
DMI Port Connector
designation Keyboard (external)
port type Keyboard Port
connector PS/2
DMI Port Connector
designation USB1 (external)
port type USB
connector Access Bus (USB)
DMI Port Connector
designation USB2 (external)
port type USB
DMI Port Connector
designation USB3 (external)
port type USB
DMI Port Connector
designation USB4 (external)
port type USB
DMI Port Connector
designation USB5 (external)
port type USB
DMI Port Connector
designation USB6 (external)
port type USB
DMI Port Connector
designation USB7 (external)
port type USB
DMI Port Connector
designation USB8 (external)
port type USB
DMI Port Connector
designation LPT 1 (external)
port type Parallel Port ECP/EPP
connector DB-25 male
DMI Port Connector
designation COM 1 (external)
port type Serial Port 16550A
connector DB-9 male
DMI Port Connector
designation LAN (external)
port type Network Port
connector RJ-45
DMI Port Connector
designation 1394_0 (external)
connector RJ-45
DMI Port Connector
designation 1394_1 (external)
connector RJ-45
DMI Port Connector
designation Audio Mic In (external)
port type Audio Port
connector Mini Jack (headphones)
DMI Port Connector
designation Audio Line In (external)
DMI Port Connector
designation Audio Line Out (external)
DMI Port Connector
designation SPDIF_OUT1 (external)
DMI Port Connector
designation CDIN (internal)
connector On Board Sound Input From CD-ROM
DMI Port Connector
designation PRI IDE (internal)
connector On Board IDE
DMI Port Connector
designation SEC IDE (internal)
DMI Port Connector
designation FLOPPY (internal)
connector On Board Floppy
DMI Port Connector
designation CHA_FAN (internal)
DMI Port Connector
designation CPU FAN (internal)
DMI Port Connector
designation FP AUDIO (internal)
DMI Port Connector
designation SB_SATA1 (internal)
DMI Port Connector
designation SB_SATA2 (internal)
DMI Extension Slot
designation PCIEX16
type A5
width 32 bits
populated no
DMI Extension Slot
designation PCIEX1
type A5
populated no
DMI Extension Slot
designation PCI1
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI2
type PCI
width 32 bits
populated yes
DMI Physical Memory Array
location Motherboard
usage System Memory
correction None
max capacity 4096MBytes
max# of devices 4
DMI Memory Device
designation DIMM0
format DIMM
type DDR
total width 64bits
data width 72bits
size 1024MBytes
DMI Memory Device
designation DIMM1
format DIMM
type DDR
total width 64bits
data width 72bits
size 1024MBytes
DMI Memory Device
designation DIMM2
format DIMM
type DDR
total width 64bits
data width 72bits
size 1024MBytes
DMI Memory Device
designation DIMM3
format DIMM
type DDR
total width 64bits
data width 72bits
size 1024MBytes
Software
Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600)
DirectX Version 9.0c
Resources
Port I/O Space, BA=0xCF8, size=0x8
Memory I/O Space, BA=0x00000000FD000000
Memory I/O Space, BA=0x00000000D0000000
Memory I/O Space, BA=0x00000000FC000000
Port I/O Space, BA=0x600
Port I/O Space, BA=0x700
Memory I/O Space, BA=0x00000000FEBDE000
Memory I/O Space, BA=0x00000000FEBDFC00
Port I/O Space, BA=0xFFA0
Port I/O Space, BA=0xE800
Port I/O Space, BA=0xE480
Port I/O Space, BA=0xE400
Port I/O Space, BA=0xE080
Port I/O Space, BA=0xE000
Memory I/O Space, BA=0x00000000FEBDD000
Memory I/O Space, BA=0x00000000FEBD8000
Port I/O Space, BA=0xD800
Memory I/O Space, BA=0x00000000FAAFFC00
Memory I/O Space, BA=0x00000000E0000000, size=0x1000
Port I/O Space, BA=0x508, size=0x4
Memory I/O Space, BA=0x00000000FEE00000, size=0x1000
Old 08-10-2010, 03:58 PM   #5 (permalink)
~ Harsh ~
hdsk.23's Avatar
anybody please help....
Old 12-10-2010, 06:20 AM   #6 (permalink)
Fast 'N' Furious
topgear's Avatar
It's the limitation of 32 bit OS and your mobos limitation in 32 bit enviroment - some mobo shows 3GB and some other shows 2.75GB ram when 4GB ram is installed but the OS you are using is a 32bit consumre grade one like xp, vista or windows 7 x86 edition.
To utilize the full amount of ram just install 64 bit version of xp, vista or windows 7 and you will be able to see and use all of 4 GB ram.
ToPsPeEeD = FaSt BuT StEaDy
topgear is online now   Reply With Quote
Old 12-10-2010, 11:52 AM   #7 (permalink)
~ Harsh ~
hdsk.23's Avatar
I have installed parallel windows 7 64bit but the problem is same..
i have googled and got the answer that motherboard reserves huge amount of ram...
Old 13-10-2010, 05:40 AM   #8 (permalink)
Fast 'N' Furious
topgear's Avatar
Your bios is showing all 4GB ram ??
Have you updated your mobos bios ?
You have 2x 2GB ram modules right ?
Try each 2GB stick at a time on every 4 slots of the mobo and see if you get 2GB showing properly - do this for all 2 ram modules of yours.
Old 13-10-2010, 04:20 PM   #9 (permalink)
~ Harsh ~
hdsk.23's Avatar
bios is showing all the ram...
and it is updated too...
the slots are of 1 GB each 1X4GB..
Old 14-10-2010, 04:19 AM   #10 (permalink)
Fast 'N' Furious
topgear's Avatar
yep, now it looks like your mobo is really reserving that amount of ram but it's very odd.
Try these :
Try clearing CMOS setting by removing the CMOS battery from mobo and put it back again after 5 mins.
There's a option called memory hole remapping or something like that in the bios options - try enabling or disabling it and see what happens.
try once again with a discrete gfx card and completely disabling the mobos IGP and all shared rams.
Old 15-10-2010, 08:57 PM   #11 (permalink)
~ Harsh ~
hdsk.23's Avatar
already done with clearing cmos...igp takes 128mb ram and if i disable it no display comes... and i have searched for remapping option but it is no where in BIOS!!
Old 15-10-2010, 08:58 PM   #12 (permalink)
~ Harsh ~
hdsk.23's Avatar
Please help anybody has faces same issue....
Old 16-10-2010, 04:34 AM   #13 (permalink)
Fast 'N' Furious
topgear's Avatar
what's the exact model no/name of your mobo ??
can you provide me the manual download link of you mobo
Old 17-10-2010, 12:14 AM   #14 (permalink)
~ Harsh ~
hdsk.23's Avatar
its ASUS mobo with Nvidia chipset. model no. is A8N-VM
having 939 socket.
and link to the manual is
http://dlcdnas.asus.com/pub/ASUS/mb/...295_a8n-vm.pdf
Old 17-10-2010, 05:41 AM   #15 (permalink)
Fast 'N' Furious
topgear's Avatar
Enter Bios setting :
go to :
Chipset >Advanced > NorBridge Config > Memory Config and look for a setting named
Software Memory Hole - enable it.
Old 17-10-2010, 04:43 PM   #16 (permalink)
~ Harsh ~
hdsk.23's Avatar
i have enabled it.. but still 2.62GB is usable...
i personally feel so embarrassed being an IT vetran i am not able to solve this issue till now...
Old 18-10-2010, 04:06 AM   #17 (permalink)
Fast 'N' Furious
topgear's Avatar
^^ try mailing asus tech support - they may tell you what exactly is happening.
Old 18-10-2010, 07:18 AM   #18 (permalink)
Super Moderator
asingh's Avatar
Could you post 3 CPU-Z screenshots. The first three tabs.
asingh is offline   Reply With Quote
Old 18-10-2010, 09:42 PM   #19 (permalink)
~ Harsh ~
hdsk.23's Avatar
here are the snapshot...
and will take the issue with Asus support too.. it seems that only they can tell what's exactly going on...
Old 18-10-2010, 11:08 PM   #20 (permalink)
~ Harsh ~
hdsk.23's Avatar
the forum from ASUS support says that the MB supports 2Gb of ram on 400FSB and 4Gb on 333FSB..
here its link too..
Kingston Technology Company - Kingston Memory Search - Search Results for:
which says
Maximum Memory: 2 GB using 400MHz DDR modules
4 GB using 333MHz or 266MHz DDR modules
what the hell is this now... now find 4gb of 333fsb.. s*ks..
Old 18-10-2010, 11:09 PM   #21 (permalink)
~ Harsh ~
hdsk.23's Avatar
anyway thanks everybody for your concern...
Old 19-10-2010, 05:26 AM   #22 (permalink)
Fast 'N' Furious
topgear's Avatar
at least you now know what the the problem is.
BTW, I've one thing in mind - try setting the ram frequency speed 333 MHz in bios.
- by chris
