Old 08-09-2010, 10:11 PM   #1 (permalink)
Default Lan problem in win xp
Hey guys
I m facing a very weird problem on my laptop. I have win xp sp3 home installed on my laptop. The problem is from the last few days my lan port /nic card icon in systray is not shown. When I check in device manager it shows ethernet controller with yellow question mark telling me that driver is not installed. But when I point it to the driver location it still doesn't get installed. Sometimes when I start up windows the ethernet controller is shown as a new hardware found and windows asks me to install drivers but when I try to do this , the drivers don't get installed.
I have already tried restoring windows from the disc from manufacturer(Toshiba). But same problem persists.
Also my dvd rom drive doesn't detect any other disc except for the recovery disc given by the manufacturer. So I can't install win7 or try linux on the laptop.
So guys please tell me if this is a hardware problem or software problem with my ethernet controller? So that I can troubleshoot the problem.
Also if u guys can think about any other way to use internet on my laptop using some converter to convert lan to some other port like usb, please do suggest so.
Thanks in advance.
ARJOT SINGH is offline   Reply With Quote
Old 08-09-2010, 10:55 PM   #2 (permalink)
XLr8
arpanmukherjee1's Avatar
Default Re: Lan problem in win xp
what router r u using??
most routers have USB type B connector. download usb driver 4 ur model no.
try UNetbootin - Homepage and Downloadsfor linux on pendrive...
have a look at http://shopping.indiatimes.com/Compu...11/pid/1730108
dont think it will help much. but still..
BTW replace the dvd of the laptop.
arpanmukherjee1 is offline   Reply With Quote
Is this a power supply problem or Geforce Graphics card problem? vps85 Graphic cards 13 09-08-2010 07:36 AM
Strange auto disconnect problem in windows 7 ayushman9 Software Q&A 1 28-04-2010 02:18 AM
Strange problem with Internet in Win XP??? go4saket Software Q&A 4 07-09-2007 11:51 PM
WIN XP MCE PROBLEM!!! aku Software Q&A 12 10-08-2005 04:40 PM
- by chris
