1.Download TC++ 3[
http://usfiles.brothersoft.com/development/c_c/tc3.zip]
2.Extract the file and run the 'install.exe'.
When you see the directory selection screen, press enter while the directories text is highlighted.Select the Turbo c++ directory as
d:\tc, [replace d: with any other drive letter other than c: if you want].Also select the binary files subdirectory as
d:\tc.Leave the rest of fields.Press esc and select start installation
3.After the installation open the installation directory [d:].Make a folder named
turboc and cut and paste the folder named
tc into this
turboc folder
4.right click on the desktop select new-->shortcut
i)type the location of the item as
"x:\Program Files\DOSBox-0.74\DOSBox.exe" -c "mount d d:\turboc" -c d: -c "tc\tc" [replace 'x:\Program Files\DOSBox-0.74\DOSBox.exe' by the actual installation path of dosbox]
ii)click next, enter a name for the shortcut and click finish
iii)Open this newly created shortcut to run turbo c
Note that running turbo c in dosbox produces undesired output for certain programs.
