Old 10-08-2010, 02:28 PM   #1 (permalink)
Fullbring
Zangetsu's Avatar
Question How to Join WMV & WMA
Hi all, I have two files .WMA & .WMV.I want to join these two files....which software can i use to do that???
Old 16-08-2010, 11:36 PM   #2 (permalink)
Your Ad here
nisargshah95's Avatar
Lightbulb Re: How to Join WMV & WMA
I guess first you should convert any one of the files into .wma or .wmv and them merge it using mp3 cutter and joiner -
MP3 Cutter Joiner - Free software downloads and software reviews - CNET Download.com
You can also merge them using Windows Movie Maker. Hope this helps!
gudluck
you can convert the files using any coversion tools available on internet
nisargshah95 is offline   Reply With Quote
is quality of wma greater than mp3? Arun the Gr8 Software Q&A 17 20-02-2008 07:50 AM
wma player doesn't play Wma files chesss Software Q&A 4 09-08-2007 11:57 AM
MP3 ringtone software for Nokia 6600 Dreamer Mobiles and Tablets 4 12-07-2006 07:30 PM
- by chris
