Old 05-08-2010, 06:27 PM   #1 (permalink)
I love girls
Default Some help in ms excel
I have got a list of about 50 names in an excel file. I need a way so that when in an another worksheet i press '1' the first name from the list gets typed, when i press '2' the second name and so on.
Please help.
007vaib is offline   Reply With Quote
Old 06-08-2010, 11:38 PM   #2 (permalink)
Om Ma Ni Pä Me Hum
phuchungbhutia's Avatar
Default Re: Some help in ms excel
Try lookup fn or vba coding. Use help to understand
Om Ma Ni Pä Me Hum: (perfection of-)
Om: generosity,- Ma: pure ethics,-Ni: tolerance n patience.- Pä: perseverance,- Me: concentration,-Hum: wisdom... Using Opera Mini Airtel NOP
phuchungbhutia is offline   Reply With Quote
Old 07-08-2010, 06:10 PM   #3 (permalink)
probably you should check this or try finding your answer in this excel forum.
http://www.mrexcel.com/forum/showthread.php?t=385637
neerajvohra is offline   Reply With Quote
XML to Excel coversion mati17 Software Q&A 0 23-04-2010 09:22 AM
Learn Excel from Mr. Excel Ramakrishnan Software Q&A 1 25-12-2006 08:27 PM
Extensions and Their Definitions Sparsh007 QnA (read only) 3 28-11-2006 07:25 PM
Missing Excel in All Programs in Win XP saigalp Software Q&A 1 03-03-2006 07:17 PM
- by chris
