Old 28-07-2010, 11:51 PM   #1 (permalink)
sujeet2555's Avatar
Default PC not booting
i am facing this problem from this morning.i run window xp sp2.pc won't boot after POST.Screen is just black,HD led is either always red or doesn't glow at all,
i have found out that when disconnected my sats dvd burner and Ide hard disk,pc boot normally.but when i connect them,problem arises.
what to do ,is it a hardware problem?please help!!
s.k.
sujeet2555 is offline   Reply With Quote
Old 30-07-2010, 01:03 AM   #2 (permalink)
Its Best only if its open
ankushkool's Avatar
Default Re: PC not booting
u have 2 hard disks? that may be causing the issue or maybe u need a PSU with higher output.
ankushkool is offline   Reply With Quote
Old 30-07-2010, 01:26 PM   #3 (permalink)
sujeet2555's Avatar
it won't even start with dvd burner attached.it was running goog day before.Btw i only use second HD for backup only.
s.k.
Old 31-07-2010, 11:31 PM   #4 (permalink)
Linoob
celldweller1591's Avatar
hardware specs plz !!
root@Celldweller#ping www.linoob.com
Ubuntu User # 31222
Linux User # 516252
celldweller1591 is offline   Reply With Quote
Old 31-07-2010, 11:38 PM   #5 (permalink)
sujeet2555's Avatar
MB-ASUS M3A78-EM
proc-AMD Phenom 9650 Quad-Core, 2310MHz
Memory-2 GB
HD-SATA 500GB ,Second HD-IDE 80GB
Burner-LG SATA BURNER
OS-xp sp2
s.k.
Old 02-08-2010, 06:34 PM   #6 (permalink)
sujeet2555's Avatar
please answer.i am not able to backup anything.
s.k.
Old 05-08-2010, 02:50 PM   #7 (permalink)
sujeet2555's Avatar
that is weird, when i select hard disk as first in boot order.pc don't start.but if i select dvd drive as first boot and hard disk as second.it starts.
what is happening here.
s.k.
Old 05-08-2010, 10:53 PM   #8 (permalink)
Cool Buddy's Avatar
pull the jumper out of your IDE HDD, things should start working.
Nokia 5230 :(
Canon IXUS 115 HS :)
Cool Buddy is online now   Reply With Quote
No Display... System booting and shutting down properly.. SOS!!! sude Hardware Q&A 28 13-08-2010 12:16 AM
os not booting - ASUS is the culprit once again ???? chiroo Hardware Q&A 3 08-07-2010 11:41 PM
Urgent help please ( laptop not booting from cd ) prasanta.voiceoflove Software Q&A 8 20-06-2010 04:27 PM
could not find kernel image : booting SGD from PenDrive anuvrat_parashar Open Source 0 08-05-2010 05:43 PM
System not booting. acewin Hardware Q&A 11 17-03-2010 06:39 PM
- by Anorion
- by tkin
- by Niilesh
