Old 10-07-2010, 03:08 PM   #1 (permalink)
Default pen drive problem in Windows XP
hello frnds, frm 2-3 days i am getting a strange problem in my Windows XP with Service Pack 3 installation. whenever i insert a pen drive in USB port, then windows hangs. but the same drive on same port runs fine in Fedora 13. can u pls tell me any solution. i hv checked but didn't find any malware.
abhijangda is offline   Reply With Quote
Old 10-07-2010, 07:52 PM   #2 (permalink)
Default Re: pen drive problem in Windows XP
Check again probably with a different Anitivirus software. If any malware is not fond, probably your pen drive has been formatted in some other format which Linux recognizes. Try to format the drive in FAT or FAT32 filesystem.
pauldmps is offline   Reply With Quote
Old 10-07-2010, 08:29 PM   #3 (permalink)
windows trying access the pendrive. but the software it uses maybe corrupted. so it gets hanged. this is just a probable reason.
Old 11-07-2010, 01:12 AM   #4 (permalink)
earlier also when i was using win xp i sometimes got this error, but i go for a reinstall, but now situation is different i cant reinstall windows. also this problem is not only associated with one pen drive, every pen drive which i insert has this problem.
Old 12-07-2010, 07:09 AM   #5 (permalink)
If I am not wrong, you might be using Quick Heal Antivirus. Disable it & see how the problem disappears magically.
problem with internet in windows 7 syner Software Q&A 4 03-06-2010 02:23 AM
Windows Seven Game Plan bijesh123 Software Q&A 2 10-05-2010 10:47 PM
Data retrieval from dead pen drive devips Hardware Q&A 2 18-02-2010 04:22 PM
Linux is NOT Windows-must read praka123 Open Source 21 27-07-2006 02:10 AM
Microsoft Windows Vista Line up product announced Shock_the_Rock_part2 Technology News 1 03-03-2006 07:33 PM
- by tkin
- by Niilesh
