Old 09-07-2010, 01:54 AM   #1 (permalink)
bajaj151's Avatar
Default How to CUT a portion of .MKV ???
I want to cut portion of screen.... (Video in .mkv )
Suggest me good software.
Phenom x6 1055T 3.75 GHz | MSI 890GXM G65 | Corsair XMS3 2*4GB 1600mhz | BenQ E2200HD | Xbox 360 Controller | Seagate 2TB | CM HAF 922 | Corsair VX 550 | Logitech MX 518 | Logitech Wireless Keyboard | Sapphire 7850 OC
bajaj151 is online now   Reply With Quote
Old 09-07-2010, 11:27 PM   #2 (permalink)
The Boy Who Lived
hjpotter92's Avatar
Default Re: How to CUT a portion of .MKV ???
I think you can use Format Factory. it has the option to cut/edit/add/merge videos.
Core i7 920 @ 2.67 GHz
Intel DX58SO
3 GB DDR3 1600 MHz RAM
nVIDIA GeForce 9600 GS
Razer Arctosa + Abyssus
Please help: http://www.thinkdigit.com/forum/prog...p-windows.html
hjpotter92 is offline   Reply With Quote
Old 10-07-2010, 08:50 AM   #3 (permalink)
bajaj151's Avatar
Actually, I want to CUT part of screen....not d video...
Old 10-07-2010, 01:22 PM   #4 (permalink)
The Boy Who Lived
hjpotter92's Avatar
OK, tht means, you have to record / take screen shots of the desktop monitor. You can use HandyCam (or maybe HyperCam) I do not know the actual name..
---------- Post added at 01:22 PM ---------- Previous post was at 01:22 PM ----------
Checked it.. it is hyper cam not handy cam..
Intel DX58SO
Old 10-07-2010, 03:24 PM   #5 (permalink)
bajaj151's Avatar
I have Video...now want to cut some portion which I don't want.
Old 10-07-2010, 07:08 PM   #6 (permalink)
The Boy Who Lived
hjpotter92's Avatar
Yes, format factory is able to do exactly which you wish to do
Intel DX58SO
Old 10-07-2010, 08:02 PM   #7 (permalink)
bajaj151's Avatar
There is an option to split the video but I want to edit the video....
Let say: This is Video
______________________
| 1
| 2
|_______________________
In this case....I don't want 2nd part...
Old 10-07-2010, 08:37 PM   #8 (permalink)
The Boy Who Lived
hjpotter92's Avatar
Yes, you can even crop the video. It is their in the right side of the window, from where you are able to cut the video. Also, I think this has been added in the version 2.30
Intel DX58SO
Old 10-07-2010, 11:47 PM   #9 (permalink)
bajaj151's Avatar
Thanks bro...finally i got it..
Old 11-07-2010, 02:21 AM   #10 (permalink)
The Boy Who Lived
hjpotter92's Avatar
That means, I was totaally sure and correct from the starting..
Intel DX58SO
Power cut effect on external Hard disk Ayush Singh Hardware Q&A 3 19-04-2010 09:03 AM
Vob to Vob cut how to do it any idea AMITAGARWAL02 Software Q&A 5 02-04-2008 01:25 AM
Fifth Undersea Internet Cable Cut ... Harvik780 Technology News 56 15-02-2008 07:33 PM
Price cut expected for Core 2 Duo?? psoft QnA (read only) 15 22-04-2007 07:50 PM
- by tkin
- by Niilesh
