Old 05-07-2010, 10:00 PM   #1 (permalink)
arian29's Avatar
Default partitions not detected.. help pls
my system has a 500gb hdd. partitions > c,d,e,f,g... c and d are under 100gb where as the rest of the partitions are larger than 100 gb. os- xp sp2. now i messed up my os and reinstalled it. win xp sp2, however now i am not able to see the partitions e,f and g. Please help.... theres lots of data in then which i cant afford to loose.. everything was working fine earlier but this time xp isnt detecting thos partitions...
http://www.twitter.com/arian29
ScAn My AvAtAr
arian29 is offline   Reply With Quote
Old 05-07-2010, 11:28 PM   #2 (permalink)
The Boy Who Lived
hjpotter92's Avatar
Default Re: partitions not detected.. help pls
use utilities like Partition magic (by power quest) or EASEUS Partition Master. they will surely help you take control on your HDD
Core i7 920 @ 2.67 GHz
Intel DX58SO
3 GB DDR3 1600 MHz RAM
nVIDIA GeForce 9600 GS
Razer Arctosa + Abyssus
Please help: http://www.thinkdigit.com/forum/prog...p-windows.html
hjpotter92 is offline   Reply With Quote
Old 05-07-2010, 11:35 PM   #3 (permalink)
cute.bandar's Avatar
what does disk management show ?
cute.bandar is offline   Reply With Quote
Old 05-07-2010, 11:46 PM   #4 (permalink)
The Boy Who Lived
hjpotter92's Avatar
Maybe, he deleted all the partitions while reinstalling.
Intel DX58SO
Old 06-07-2010, 03:04 AM   #5 (permalink)
Linoob
celldweller1591's Avatar
paste the output of
fdisk /status
or
1)
list disk
2)
list volume
here.
root@Celldweller#ping www.linoob.com
Ubuntu User # 31222
Linux User # 516252
celldweller1591 is offline   Reply With Quote
Old 06-07-2010, 12:12 PM   #6 (permalink)
arian29's Avatar
the dos commands did not show anything...
partition magic aint helping
screenshot of disk management >>
Uploaded with ImageShack.us
ScAn My AvAtAr
Old 06-07-2010, 09:14 PM   #7 (permalink)
You really messed up! Your 337.77 GB unallocated is your lost partitions. sadly, your Drive D contains almost nothing. I really home that you can still recover your lost data but don't know how.
thenishant is offline   Reply With Quote
Old 07-07-2010, 06:48 PM   #8 (permalink)
I suggest you to try linux live CD and just hope you may find the data intact but if you have really messed up and aren't telling clearly then then then .....
Abhinav
abhinav_sinha is offline   Reply With Quote
Old 08-07-2010, 10:18 AM   #9 (permalink)
CA50's Avatar
you can try partition find and mount to mount your lost partition
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
CA50 is offline   Reply With Quote
Old 09-07-2010, 02:25 PM   #10 (permalink)
arian29's Avatar
yippieeee ! i recovered all the data from the lost partition.. thanks to Steller data recover . thanks to u all
ScAn My AvAtAr
Maximum number of hard disk partitions reached vjunloc Hardware Q&A 5 21-06-2010 09:11 AM
Pls HELP !!!! Acer 5740G/ Sony VPC-EB14/ Dell Inspiron 15R siddharth1703 Hardware Q&A 2 04-06-2010 05:15 PM
Pls help me to plan my new rig config arthur5552000 PC Components / Configurations 17 27-04-2010 07:47 PM
Due Kernel I/O error, system refuses to boot randomly gary4gar Open Source 33 04-05-2008 10:22 AM
IITd online treasure hunt "Krypton" started fun2sh Random News 1005 07-03-2008 05:44 PM
- by tkin
- by Niilesh
