Old 02-07-2010, 11:10 AM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
change is constant!!
khmadhu's Avatar
Question USB portable HDD low level format tool
Hi frens..
My 500 GB seagate freeagent USB HDD got crashed ,
its showing all the partitions but cannot access any drives
I tried all software's to recover my data..but no luck..
so decided to do low level format. using HDDguru software and partition magic 9.
and also checked with windows checkdisk. but no use.
i tried HDD regerator to fix bad sectors but its taking too much time more than 170 Hrs
can anyone suggest me a good tool to do entire disk partition and format(for very bad disk)..?
if nothing works i wlll go for replacement. anyhow it has 5 years warranty..
If you really wanna think, try to think from Atom to Universe!!
cpu: core i5 2500k, mobo: DP67BG, RAM:Corsair 8GB(4x2) 1600 Mhz, XFX HD 5770, 1TB seagate 6Gbps 7200 rpm , SAGA II 500W
khmadhu is offline   Reply With Quote
Old 06-07-2010, 07:58 AM   #2 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Default Re: USB portable HDD low level format tool
You really cannot "fix" bad sectors. All your "fix"ing tools just hide the bad sectors. If you have lots of them, send it for replacement. You should get a new one in ~ 20 days
dheeraj_kumar is offline   Reply With Quote
Old 06-07-2010, 11:16 AM   #3 (permalink)
khmadhu's Avatar
sent it for replacement. will get in 5-7 days..
LinkBack to this Thread: http://www.thinkdigit.com/forum/software-q/128978-usb-portable-hdd-low-level-format-tool.html
portable low level format This thread Refback 11-09-2011 02:17 PM
Purchasing a new 1TB USB Hard Disk insaneYLN Hardware Q&A 14 08-05-2012 05:29 AM
[Tutorial]Windows Vista- Snipping Tool narangz Tutorials 19 01-03-2008 10:31 AM
Confusion in choosing right file system for Portable USB HDD It_is_Andrew Peripherals 4 01-02-2006 09:57 PM
Dangerous Dave Prashray Gamerz 29 16-11-2004 07:46 PM
- by tkin
- by Niilesh
