I suspect the same....
Checked CPU temp in BIOS: 65-70 deg C
Checked after booting using SpeedFan : 75-80 deg C
after constantly monitoring the Temp, found it shook upto 100 deg C. (during CPU usage 100%)
Also, fan1 is working sometimes, and sometimes not, though dont know which fan it is.
There are some Voltages readings also like this.... (if you need them, i can post them too...)
Now Problem No. 2:
I wanted to make a fresh xp installation, but again the problem of "Black Screen" comes out. After booting from the CD, and then "system is inspecting your computer hardware configuration" (something like this) the screen goes Black and nothing happens after that.....tried several times and used several tools to check the problem but no result.
What i am missing.....plz help me out !!
---------- Post added at 08:22 PM ---------- Previous post was at 08:10 PM ----------
@dheeraj, whats with the HijackThis log,
Anyways, i ran the HijackThis and here is the log (y the forum doesnt support txt attachments
Logfile of Trend Micro HijackThis v2.0.4
Scan saved at 8:02:00 PM, on 7/7/2010
Platform: Windows XP SP2 (WinNT 5.01.2600)
MSIE: Internet Explorer v6.00 SP2 (6.00.2900.2180)
Boot mode: Normal
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\winlogon.exe
C:\WINDOWS\system32\services.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\system32\svchost.exe
C:\WINDOWS\System32\svchost.exe
C:\WINDOWS\system32\spoolsv.exe
C:\Program Files\Java\jre6\bin\jqs.exe
C:\Program Files\Norton Ghost\Agent\VProSvc.exe
C:\Program Files\Cyberlink\Shared files\RichVideo.exe
C:\Program Files\Alcohol Soft\Alcohol 120\StarWind\StarWindService.exe
C:\WINDOWS\system32\dllhost.exe
C:\WINDOWS\Explorer.EXE
C:\WINDOWS\System32\TUProgSt.exe
C:\WINDOWS\system32\wscntfy.exe
C:\WINDOWS\RTHDCPL.EXE
C:\WINDOWS\system32\igfxpers.exe
C:\Program Files\Norton Ghost\Shared\Drivers\SymSnapService.exe
C:\WINDOWS\system32\igfxtray.exe
C:\WINDOWS\system32\hkcmd.exe
C:\Program Files\SpeedFan\speedfan.exe
C:\Documents and Settings\Pradeep\Local Settings\Application Data\Google\Chrome\Application\chrome.exe
C:\WINDOWS\system32\taskmgr.exe
C:\Documents and Settings\Pradeep\My Documents\Downloads\HijackThis.exe
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = Yahoo! India
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = Yahoo! Search - Web Search
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = Yahoo! Search - Web Search
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = Yahoo! India
O2 - BHO: (no name) - {02478D38-C3F9-4efb-9B51-7695ECA05670} - (no file)
O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelper.dll
O2 - BHO: IEVkbdBHO - {59273AB4-E7D3-40F9-A1A8-6FA9CCA1862C} - C:\Program Files\Kaspersky Lab\Kaspersky Internet Security 2010\ievkbd.dll
O2 - BHO: Java(tm) Plug-In 2 SSV Helper - {DBC80044-A445-435b-BC74-9C25C1C588A9} - C:\Program Files\Java\jre6\bin\jp2ssv.dll
O2 - BHO: link filter bho - {E33CF602-D945-461A-83F0-819F76A199F8} - C:\Program Files\Kaspersky Lab\Kaspersky Internet Security 2010\klwtbbho.dll
O2 - BHO: JQSIEStartDetectorImpl - {E7E6F031-17CE-4C07-BC86-EABFE594F69C} - C:\Program Files\Java\jre6\lib\deploy\jqs\ie\jqs_plugin.dll
O4 - HKLM\..\Run: [SkyTel] SkyTel.EXE
O4 - HKLM\..\Run: [RTHDCPL] RTHDCPL.EXE
O4 - HKLM\..\Run: [Persistence] C:\WINDOWS\system32\igfxpers.exe
O4 - HKLM\..\Run: [IgfxTray] C:\WINDOWS\system32\igfxtray.exe
O4 - HKLM\..\Run: [HotKeysCmds] C:\WINDOWS\system32\hkcmd.exe
O4 - HKLM\..\Run: [BluetoothAuthenticationAgent] rundll32.exe bthprops.cpl,,BluetoothAuthenticationAgent
O4 - HKLM\..\Run: [Alcmtr] ALCMTR.EXE
O4 - HKLM\..\Run: [avp] "C:\Program Files\Kaspersky Lab\Kaspersky Internet Security 2010\avp.exe"
O4 - HKLM\..\Run: [UpdatePDRShortCut] "D:\@@ installed applications\PowerDirector\PowerDirector\MUITransf er\MUIStartMenu.exe" "D:\@@ installed applications\PowerDirector\PowerDirector" UpdateWithCreateOnce "Software\CyberLink\PowerDirector\8.0"
O8 - Extra context menu item: Add to Anti-Banner - C:\Program Files\Kaspersky Lab\Kaspersky Internet Security 2010\ie_banner_deny.htm
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~2\OFFICE11\EXCEL.EXE/3000
O9 - Extra button: &Virtual keyboard - {4248FE82-7FCB-46AC-B270-339F08212110} - C:\Program Files\Kaspersky Lab\Kaspersky Internet Security 2010\klwtbbho.dll
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~2\OFFICE11\REFIEBAR.DLL
O9 - Extra button: URLs c&heck - {CCF151D8-D089-449F-A5A4-D9909053F20F} - C:\Program Files\Kaspersky Lab\Kaspersky Internet Security 2010\klwtbbho.dll
O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O9 - Extra 'Tools' menuitem: Windows Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O20 - AppInit_DLLs: C:\PROGRA~1\KASPER~1\KASPER~2\mzvkbd3.dll,C:\PROGR A~1\KASPER~1\KASPER~2\kloehk.dll
O22 - SharedTaskScheduler: Browseui preloader - {438755C2-A8BA-11D1-B96B-00A0C90312E1} - C:\WINDOWS\system32\browseui.dll
O22 - SharedTaskScheduler: Component Categories cache daemon - {8C7461EF-2B13-11d2-BE35-3078302C2030} - C:\WINDOWS\system32\browseui.dll
O23 - Service: Kaspersky Internet Security (AVP) - Kaspersky Lab - C:\Program Files\Kaspersky Lab\Kaspersky Internet Security 2010\avp.exe
O23 - Service: Java Quick Starter (JavaQuickStarterService) - Sun Microsystems, Inc. - C:\Program Files\Java\jre6\bin\jqs.exe
O23 - Service: LiveUpdate - Symantec Corporation - C:\PROGRA~1\Symantec\LIVEUP~1\LUCOMS~1.EXE
O23 - Service: Norton Ghost - Symantec Corporation - C:\Program Files\Norton Ghost\Agent\VProSvc.exe
O23 - Service: Cyberlink RichVideo Service(CRVS) (RichVideo) - Unknown owner - C:\Program Files\Cyberlink\Shared files\RichVideo.exe
O23 - Service: ServiceLayer - Nokia. - C:\Program Files\PC Connectivity Solution\ServiceLayer.exe
O23 - Service: Start BT in service - Unknown owner - C:\Program Files\IVT Corporation\BlueSoleil\StartSkysolSvc.exe
O23 - Service: StarWind iSCSI Service (StarWindService) - Rocket Division Software - C:\Program Files\Alcohol Soft\Alcohol 120\StarWind\StarWindService.exe
O23 - Service: SymSnapService - Symantec - C:\Program Files\Norton Ghost\Shared\Drivers\SymSnapService.exe
O23 - Service: TuneUp Drive Defrag Service (TuneUp.Defrag) - TuneUp Software - C:\WINDOWS\System32\TuneUpDefragService.exe
O23 - Service: TuneUp Program Statistics Service (TuneUp.ProgramStatisticsSvc) - TuneUp Software - C:\WINDOWS\System32\TUProgSt.exe
End of file - 7168 bytes
