Old 23-06-2010, 01:35 AM   #1 (permalink)
Unhappy folder lock problem.
pls i need some one to help me.i used a trial version of 'folder lock 6' for 4 days before a friend introduced me to a crack version that is working perfectly on his system.i uninstalled the trial version and installed the crack version which was 'folder lock 5.8.0'.it worked perfectly well after a day, and allowed me lock my important document in it.after a day it stopped working.anytime i try to unlock ,it accept the password,but does not open and the error displays on microsoft windows as-'fast,reliable,portable and powerful.has stopped workin'. windows never notify me on the solution.pls could anyone help my.my valued documents are stocked.
abas is offline   Reply With Quote
Old 23-06-2010, 02:28 PM   #2 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Default Re: folder lock problem.
That should teach you to be careful in the future. TDF does not support cracked software, and certainly not ppl who trust an illegal copy to protect sensitive files.
try this:
FOLDER LOCK PROBLEM; URGENT
dheeraj_kumar is offline   Reply With Quote
Old 23-06-2010, 03:57 PM   #3 (permalink)
cute.bandar's Avatar
OH no! sara porn lock ho gaya
Anyways you can use a live linux cd to recover all your files. Also post the exact error message you get.
cute.bandar is offline   Reply With Quote
Old 24-06-2010, 02:31 AM   #4 (permalink)
CA50's Avatar
try this:
+1, no piracy in TDF
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
CA50 is offline   Reply With Quote
Old 24-06-2010, 04:04 AM   #5 (permalink)
Why using the software to lock folders when you originally can create codes to do it.
source
neerajvohra is offline   Reply With Quote
Folder is not accessible....... heartripple Software Q&A 10 01-12-2010 01:45 PM
Yet another BSOD problem phuchungbhutia Software Q&A 7 17-06-2010 12:31 PM
Wierd LCD problem Psychosocial Hardware Q&A 2 10-03-2010 02:20 AM
Recovering from a corrupted regisry which is stopping windows xp to start piyushp_20 Tutorials 2 14-07-2007 01:40 PM
Customizing Windows XP Home Edition : Just for nOObs Quiz_Master Tutorials 2 21-01-2006 12:19 PM
- by tkin
- by Niilesh
