Old 17-06-2010, 02:56 PM   #1 (permalink)
mekalodu
iinfi's Avatar
Question change default search engine string in FF
hi all
when i search from the search box in the address bar in firefox, it always searches from google.ae as i am in uae now.
i want it to search from google.co.in or a google.com. Is it possible to change it?
i changed the about.config >> keyword.URL to http://www.google.co.in/search?ie=UT...ient&gfns=1&q=
but it doesnt help me!
can someone plz guide me?
thanks
iinfi is offline   Reply With Quote
Old 17-06-2010, 05:00 PM   #2 (permalink)
swatkat's Avatar
Default Re: change default search engine string in FF
The Keyword.URL config option is only for address bar searching. If you want to change behavior of search box, then use this add-on:
https://addons.mozilla.org/en-US/firefox/addon/51000/
http://swatrant.blogspot.com/
swatkat is offline   Reply With Quote
Old 17-06-2010, 08:50 PM   #3 (permalink)
mekalodu
iinfi's Avatar
thank you man .... u dont come here often these days is it?? ur posts r always useful ...
thanks for ur help ...
Old 18-06-2010, 01:39 PM   #4 (permalink)
swatkat's Avatar
You're welcome Yes, it's been a long time since I visited the forums.
Bug in digit search function !!! esumitkumar Software Q&A 2 19-02-2010 07:35 PM
Packages+Dependencies for OpenSuSE 10.3 x86_64 NucleusKore Open Source 9 11-05-2008 07:40 PM
.:Removal of 'My Search Bar':. pradisdeep Tutorials 1 07-12-2006 01:44 AM
Problem configuring canon i255 printer mehulved Open Source 31 10-02-2006 12:16 AM
Some Registry tweaks ....try it at your own risk! U2 Tutorials 2 17-12-2005 11:17 AM
- by Niilesh
- by Krow
