Old 17-06-2010, 11:51 AM   #1 (permalink)
Om Ma Ni Pä Me Hum
phuchungbhutia's Avatar
Default Bootable xp recovery, help
I m chnging my harddisk n i want to know if there is some way to create recovery disk in xp like that in vista or 7. I will need to create same installation in new hd, plus i m not going to use old hd.
Which software is better n will i get to choose what appl i can include in it, if possible.
Om Ma Ni Pä Me Hum: (perfection of-)
Om: generosity,- Ma: pure ethics,-Ni: tolerance n patience.- Pä: perseverance,- Me: concentration,-Hum: wisdom... Using Opera Mini Airtel NOP
phuchungbhutia is offline   Reply With Quote
Old 17-06-2010, 01:36 PM   #2 (permalink)
cute.bandar's Avatar
Default Re: Bootable xp recovery, help
IF you just want to tranfer your OS and data from old hdd to the new HDD, then simply use something like acronis true image .
cute.bandar is offline   Reply With Quote
Old 28-08-2010, 10:26 AM   #3 (permalink)
In this situation I would suggest u to go for Disk Cloning . This is the best solution in order to minimize the chances of data loss. The software I would suggest is Stellar Phoenix Windows data recovery software , which I have used 2 months ago.
davison4 is offline   Reply With Quote
Hard disk data recovery........? test1234xyz Hardware Q&A 8 22-05-2010 04:54 PM
hp recovery disc problem anant197 Software Q&A 2 10-04-2010 08:23 PM
Tutor: Using The Recovery Console Gigacore Tutorials 36 03-09-2007 07:16 AM
How to install and use the Recovery Console in Windows XP DukeNukem Tutorials 2 04-11-2006 02:01 AM
How To Use The Recovery Console In Windows Xp dj{IB} Tutorials 1 17-10-2005 05:11 AM
- by Niilesh
- by Krow
