Old 16-06-2010, 12:33 PM   #1 (permalink)
Default adobe reader 9.3 problems
my adobe reader 9.3 downloaded from the net doesnt work properly stopping every now and then.whats the solution
andy_65_in is offline   Reply With Quote
Old 16-06-2010, 04:47 PM   #2 (permalink)
swatkat's Avatar
Default Re: adobe reader 9.3 problems
Do you get any error? Try reinstalling Adobe Reader, or use alternate software like Foxit Reader ( http://www.foxitsoftware.com/pdf/reader/ ).
http://swatrant.blogspot.com/
swatkat is offline   Reply With Quote
Old 16-06-2010, 08:23 PM   #3 (permalink)
The Boy Who Lived
hjpotter92's Avatar
+1 for Foxit. it is free and small,
Core i7 920 @ 2.67 GHz
Intel DX58SO
3 GB DDR3 1600 MHz RAM
nVIDIA GeForce 9600 GS
Razer Arctosa + Abyssus
Please help: http://www.thinkdigit.com/forum/prog...p-windows.html
hjpotter92 is offline   Reply With Quote
Old 16-06-2010, 08:25 PM   #4 (permalink)
Tech.Masti's Avatar
Yes.... use Foxit...
Tech.Masti is offline   Reply With Quote
Old 08-07-2010, 09:45 AM   #5 (permalink)
i still cant read adobe files using the foxit reader.i tried installing the adobe again(without uninstalling the foxit) but it doesnt work.how can i see adobe files using foxit.pl help
Old 08-07-2010, 11:43 AM   #6 (permalink)
geek........
Gauravs90's Avatar
^^ yur pdf files have become corrupted if they are not opening with foxit
Gauravs90 is online now   Reply With Quote
Old 08-07-2010, 11:44 AM   #7 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Can you explain what you mean by "it doesn't work"? If you can be a bit detailed, we can understand your problem better.
dheeraj_kumar is offline   Reply With Quote
Old 08-07-2010, 12:03 PM   #8 (permalink)
Democracy is a myth
rhitwick's Avatar
Are all ur PDF files not opening in Adobe and Foxit? or any particular file?
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
rhitwick is online now   Reply With Quote
Windows 7 problems IronCruz Software Q&A 3 09-02-2010 05:05 PM
windows 7 & catalyst 10.1 problems... himadri_sm Software Q&A 0 02-02-2010 12:38 AM
Adobe Reader 8 relesed brutality9k Technology News 17 12-12-2006 07:16 AM
Adobe Reader william Software Q&A 1 07-03-2006 12:52 AM
Adobe Announces Acrobat 7.0 Software Availability naveenchandran Software Q&A 3 02-03-2005 12:50 PM
- by Niilesh
- by Krow
