Old 14-06-2010, 08:28 PM   #1 (permalink)
Om Ma Ni Pä Me Hum
phuchungbhutia's Avatar
Default Yet another BSOD problem
My friend had xp loaded and it was causing problem since last 2 weeks, he could start the sys a week ago , even tried reinstalling but xp cd wont even copy the dll while setup. So i installed vista into the system, but that was giving errors n restrting at times n crashing programs. Then he asked me to install xp instead so i did that today, i loaded n all setup was ok, but he called me again n said it wont start , its howing bsod problem.
Wht can be the problem source n remedy. Is there some new virus prob.
He has genuine kaspersky n uses internet to play warcraft online, n nothing else. Is kasp any good, it mayb its not detecting.
how to resolve this prob
any softwre or tehnique to pass this,pl help me.
Om Ma Ni Pä Me Hum: (perfection of-)
Om: generosity,- Ma: pure ethics,-Ni: tolerance n patience.- Pä: perseverance,- Me: concentration,-Hum: wisdom... Using Opera Mini Airtel NOP
phuchungbhutia is offline   Reply With Quote
Old 14-06-2010, 08:54 PM   #2 (permalink)
Linoob
celldweller1591's Avatar
Default Re: Yet another BSOD problem
There's a little chance that Kasper misses malware. BSODs are not only coz of malware, its mainly due to bad hardware or some unsupported drivers or latest upgrade into unsupported hardware causing system crash. This may be due to a faulty HDD or memory module. You must give me the BSOD techinical code to analyse the actual fault. To do that, follow:-
  1. Click Start, point to Settings, and then click Control Panel.
  2. Double-click System.
  3. Click the Advanced tab, and then click Settings under Startup and Recovery.
  4. In Write Debugging information list, click Small memory dump (64k).
Then, goto C:\windows\minidump\minidump.dmp .Post the file here.
root@Celldweller#ping www.linoob.com
Ubuntu User # 31222
Linux User # 516252
celldweller1591 is offline   Reply With Quote
Old 14-06-2010, 10:17 PM   #3 (permalink)
Om Ma Ni Pä Me Hum
I forgot to mention that he had installed graphics card nvdia 9400 gt may b thats the real cause , in such a case what would you recommend.
Wher can i get new driver , the device mgr dont show no wrong, the nvidia software says its ok.
i ll ask him to give me that dump report. Thanks for the help
Old 15-06-2010, 06:48 AM   #4 (permalink)
Linoob
Ya.. thay may be the problem but w/o technical info, cant say much about it. Try running after removing the card from the slot. Tell your friend to download bluescreenview and post bsod.txt here .
Ubuntu User # 31222
Linux User # 516252
Old 15-06-2010, 07:43 AM   #5 (permalink)
RAM modules could be a cause too... are u getting any page faults in non-paging area ?
Huzefa is offline   Reply With Quote
Old 15-06-2010, 07:39 PM   #6 (permalink)
Linoob
just a possibility. W/o BSOD, you cant really tell about the exact faulty hardware or device driver.
Ubuntu User # 31222
Linux User # 516252
Old 17-06-2010, 12:06 PM   #7 (permalink)
Om Ma Ni Pä Me Hum
I hv exam goin on havent been to his place . My fren said he installed vista again,. . . but kaspersky seem to hav deleted some files from c drive n he getting prob n he removed kaspersky, . -
i ll get that dump report in some days. Thanks for ur valuable help.
ps can u suggest better antivirus than kasp which has least no of false detections pl
Old 17-06-2010, 12:31 PM   #8 (permalink)
Linoob
Nod32 or Avast pro but i cant make sure that they will run better in vista (bloatware) I had a hard time fixing a friends computer with Vista. Its a headache !!
Wheneva u get time, just attach that .dmp file and i will see to it !
Ubuntu User # 31222
Linux User # 516252
Dell Studio 15 Display Inverter and DVD Writer Problem windchimes Hardware Q&A 2 24-05-2010 12:48 AM
Ubuntu 10.04 "Low Graphics Mode" problem after update krishnandu.sarkar Open Source 6 23-05-2010 05:35 AM
problem with 16GB Cruzer micro rohit330 Hardware Q&A 3 16-05-2010 08:59 PM
Problem in Copy/cut paste bhavik Software Q&A 2 15-05-2010 10:52 AM
APC UPS problem prvprv Hardware Q&A 1 28-01-2010 05:08 PM
- by Niilesh
- by Krow
