I have these viruses and trojans in the Windows\temp folder. I tried deleting the folder but doesnt. Also doesnt detect thru NOD32 and KAV.
They are
1. Torjan horse Java/Class Leader
2. Virus identified Java/Byte Verify.
How do I eliminate them?
Java Byte Verify is a vulnerability. You can remove the threat by cleaning the Java JAR Cache. Follow these steps:-
Go to Start > Settings > Control panel > Java Plugin. Here click "Delete Files" under the "Temporary Internet Files" dialog box.
Those temp files are being used by some other application. That's why, you can not delete it. Check whether you can delete those files in safe mode.
Java Byte Verify is a vulnerability, and is itself does not do any harm. Some of the files in Java VM contains "viral" code, but they are not allowed to run or load into memory, and this is detected by AntiViruses as viruses. Microsoft has released a patch for this, you can get it here. http://www.microsoft.com/technet/sec.../MS03-011.mspx
