Old 09-06-2010, 12:31 PM   #1 (permalink)
prttal's Avatar
Question Sun VirtualBox help
I want to try out OpenSolaris and so I downloaded Virtualbox but I have only 512 MB of RAM on my PC which runs on an AMD Athlon XP. So can anybody suggest me a lighter version of it which uses either GNOME or KDE not any other desktop manager.
prttal is offline   Reply With Quote
Old 09-06-2010, 12:48 PM   #2 (permalink)
God of Mistakes...
Garbage's Avatar
Default Re: Sun VirtualBox help
Better to burn a CD/DVD and boor from that instead of VirtualBox, as your RAM is too low.
Registered Linux User #468778
http://twitter.com/_Garbage_
Garbage is offline   Reply With Quote
Old 09-06-2010, 05:27 PM   #3 (permalink)
Linoob
celldweller1591's Avatar
512 mb is very less for running virtual machine like opensolaris. Instead, use it live or install it on HDD
root@Celldweller#ping www.linoob.com
Ubuntu User # 31222
Linux User # 516252
celldweller1591 is offline   Reply With Quote
Old 10-06-2010, 07:08 PM   #4 (permalink)
prttal's Avatar
But I found an Ubuntu light distribution called XUbuntu. It works on RAM less than 192 Mb.
Old 10-06-2010, 08:26 PM   #5 (permalink)
Linoob
yup, Lubuntu is rahter more light but to run Host you need 200 mb atleast (XP or Ubuntu is considered). then Vbox needs 80mb atleast to run all its services and its network manager and other things. Then your Guest OS will need 200mb (approx) Total comes upto 480mb and you have 512mb. Seems to me a risky thing prone to crash as in Xp you will have Av program with Realtime shield taking immediate cpu cycles when Vbox will be running. If a firewall is there, its hell impossible. Rest upto you.
Ubuntu User # 31222
Linux User # 516252
Mac OS on your Windows PC using VirtualBox ? kthanigai Software Q&A 14 11-08-2010 11:17 PM
indias first HD broadcast starts by sun DTH Baker Chit-Chat 3 12-03-2010 07:42 PM
Sun Microsystems Announces Agreement to Acquire innotek coolpcguy Technology News 6 28-02-2008 12:19 PM
State aided terror to stop SUN DTH !!! vaithy Random News 12 19-02-2008 10:05 AM
.:: Sun's Open-Source Patent Policies Being Questioned ::. tuXian Open Source 1 15-02-2005 02:48 AM
- by Niilesh
- by Krow
